Need assistance routing inbound calls from a SIP trunk to different extensions in different partitions
John Platts
Level 4
Level 4
I already have the CUCM system installed, and I have already added the SIP trunk. I need assistance routing different numbers coming in over this SIP trunk to different partitions.
Here is a list of patterns coming into the SIP trunk, along with the partitions that these calls need to be routed to:
19722320XXX -> Extensions 2XXX in Partition_A
1972874XXXX -> Extensions XXXX in Partition_B
168222763XX -> Extensions 40XX in Partition_C
19722081000 -> Extension 2000 in Partition_A
19725383191 -> Extension 3000 in Partition_B
18175723897 -> Extension 4000 in Partition_C
How do I configure CUCM 10 to route these numbers coming in to the appropriate partitions? All of the above patterns are coming in over the same SIP trunk, but I need help getting these numbers routed correctly to their proper destinations.
Jaime Valencia
Configure the translation patterns to do that routing, that's all you need.
Turn that data you posted, into TPs.
java
if this helps, please rate
Jaime Valencia
java
