need example configuration voip router série 2900
adam_obayid
Héyyy
please i have the router série 2090 , i want to configure voip in the router , so i need example the configuration, and i want to know how to configure voip in this router by line command or graphic ??
7 Replies 7
Jaime Valencia
You'll have to be a lot more specific about what you need, "I need to configure VoIP" is a very broad statement, you'll do all via CLI.
There's already plenty of documentation on cisco.com, about how to configure voice related features, you can also find examples on CSC or google, have you reviewed any of those??
java
if this helps, please rate
héy Mr jaime valencia
I inform you that I Router 2900 series and IP telephony, I want to configure the router but I need example configuration
Again, that's a very broad question. Do you want CME?? CUBE?? PRI?? FXO?? SIP trunk?? etc
And if any of the above, have you tried searching the configuration guides on cisco.com or google??
If you have no experience with any of those, it would be in your best interest to hire a consultant or a Cisco partner for this configuration.
java
i need to configuration CME , i have router cme 2900 serie, i want to configure "registration account sip lan" , "pstn to sip (incoming call)"  and sip  tp pstn (outgoing call)
cordialy
Here's the documentation
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm.html
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-express/91535-cme-sip-trunking-config.html
java
Aseem Anand
Hi Adam,
Refer to the link below:
http://www.cisco.com/c/en/us/td/docs/routers/access/1900/software/configuration/guide/Software_Configuration/voice.html
Aseem
thinks Mr Aseem
i need a example configuration for to start the telephone posts its urgent !!!
