01-07-2015 02:06 PM - edited 03-17-2019 01:31 AM
Folks,
I need guidance on understanding the Dial-peers and Translations-profiles.
I must have read the help-guide 10 or more times;but the sequence of how the router process the dial-peers and translation-rules
is just not working for me.
Can anyone help me with this? What can i do to get better understanding; I have a CME system i'm using for practice: but all the rules and sequences are not coming together for me.
HELP,
Anthony
01-07-2015 04:29 PM
Have you read these:
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/14074-in-dial-peer-match.html
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/64020-number-voice-translation-profiles.html
Also if you explain your configuration and what you are trying to do. ie send calls from an IP Phone to PSTN over ISDN, etc maybe able to provide some more assistance.
01-07-2015 09:26 PM
Heathrw,
thanks for the reply. Here is my first issue:
1. i just setup a cme configuration with one router; my cme router; i have two IP phones connected to a switch and cme router connected to the switch. IP phone1 ext = 1000; and IP phone2 ext = 1001.
I have a SIP provider that provides my SIP trunk with a DID number (5713132222).
I can make call successfull calls from IP phone1 to IPhone2 and vice versa.
I can make outgoing call over the SIP trunk to PSTN;
I can make incoming calls into my CME router via SIP trunk DID number.
ISSUE: i have no dial-peers configured for incoming calls via DID number into my CME router, but
when i make an incoming call via SIP trunk via DID number, the IP phone1 rings; let me say when making incoming DID call i'm dialing DID number (5713132222), but my IP phone1 with ext 1000 rings; I can answer and get talkpath.
How dailing the DID number makes my IP phone ext 1000 rings? When is the dial-peer that is converting from DID # to my ext #?
thanks
01-07-2015 09:41 PM
So you only have a single number or a range of numbers?
Can you please attach the following files.
01-08-2015 08:29 AM
Yes, I have a single number for DID.
01-08-2015 02:31 PM
Are you going attach the other info?
01-08-2015 02:40 PM
I sent an attached file this morning;
But here is the Running-config and debug file
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.01.08 09:57:29 =~=~=~=~=~=~=~=~=~=~=~=
no debug alldebug ccsip messagesshow runn
Building configuration...
Current configuration : 6659 bytes
! No configuration change since last restart
version 15.0
hostname LAP_3825_1PORT
boot-start-marker
boot-end-marker
enable secret 5 $1$X8TI$9GWQ1D3/.FKSn5P4t0JXV0
no aaa new-model
clock timezone est -5
clock summer-time est recurring
no network-clock-participate wic 2
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 192.168.x.x 192.168.x.x
ip dhcp pool DATA_NET
network 192.168.x.x 255.255.255.0
default-router 192.168.x.x
dns-server 8.8.8.8
lease 0 8
ip dhcp pool VOICE_NET
option 150 ip 192.168.x.x
--More-- dns-server 8.8.8.8
lease 0 8
no ipv6 cef
voice-card 0
voice service voip
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
registrar server expires max 3600 min 3600
localhost dns:sip.nextiva.com
voice class codec 1
codec preference 1 g711ulaw
crypto pki trustpoint TP-self-signed-1795450327
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1795450327
revocation-check none
rsakeypair TP-self-signed-1795450327
crypto pki certificate chain TP-self-signed-1795450327
certificate self-signed 01
30820246 308201AF A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 31373935 34353033 3237301E 170D3135 30313038 31353234
32315A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 37393534
--More-- 35303332 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100E4EF 5E4F6C70 5BBE7294 E380E233 3AA138AD F7FE3F02 620C3647 3F07E2D9
15BA8FF7 44B3D3DE 2545C73E 4E75459A B009D059 5DA7D046 00E15C0A 809E566B
2503030F B132061E 91EF4700 C8B37EF8 77A28DBD 4902A31E 89267D34 C8991BAB
21925BD9 3EB00675 DF575B4A 09798382 BC79727B 0C142BBF 2CD06CF8 12BC3A37
0A890203 010001A3 6E306C30 0F060355 1D130101 FF040530 030101FF 30190603
551D1104 12301082 0E4C4150 5F333832 355F3150 4F525430 1F060355 1D230418
30168014 C841C642 4FD9B2AD 93AC67B5 7E6B8377 684A89DC 301D0603 551D0E04
160414C8 41C6424F D9B2AD93 AC67B57E 6B837768 4A89DC30 0D06092A 864886F7
0D010104 05000381 81003767 467B64AC 47557C30 5011FFD4 892170DF 0A86E871
67C37A9A 2EB2D5DF BB53857D 1748459B C81B9202 F9E30468 D19A6261 C0D0473F
8E41A72B 9CE04D81 C41CB132 23ED61F3 14B17D47 B1F42B6A 48623787 CBEAF4B6
D1016A8D 067BDF44 978E52EF 876A6028 93F902CD A1F0B2B6 D8590287 C0B06A1A
5DE021C4 B2D24A87 9C4C
quit
license udi pid CISCO3825 sn FTX1112A2NV
username Anthony1 password 0 cisco
redundancy
controller T1 0/2/0
controller T1 0/2/1
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/0.1
description OUTSIDE INTERFACE
encapsulation dot1Q 1 native
--More-- ip address dhcp
ip nat outside
ip virtual-reassembly
interface GigabitEthernet0/0.2
description VOICE VLAN INTERFACE
encapsulation dot1Q 2
ip address 192.168.x.x 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.3
description DATA VLAN INTERFACE
encapsulation dot1Q 3
ip nat inside
interface Service-Engine0/0
ip unnumbered GigabitEthernet0/0.2
service-module ip address 192.168.x.x 255.255.255.0
service-module ip default-gateway 192.168.x.x
interface GigabitEthernet0/1
no ip address
ip nat outside
shutdown
duplex auto
speed auto
media-type rj45
ip forward-protocol nd
ip http server
ip http secure-server
ip nat inside source list 10 interface GigabitEthernet0/0.1 overload
ip route 192.168.x.x 255.255.255.255 Service-Engine0/0
access-list 10 permit 192.168.x.x 0.0.0.255
--More-- !
tftp-server flash:phone/7940-7960/P00308000500.bin alias P00308000500.bin
tftp-server flash:phone/7940-7960/P00308000500.loads alias P00308000500.loads
tftp-server flash:phone/7940-7960/P00308000500.sb2 alias P00308000500.sb2
tftp-server flash:phone/7940-7960/P00308000500.sbn alias P00308000500.sbn
control-plane
voice-port 0/0/0
voice-port 0/0/1
dial-peer voice 300 voip
description *** outbound from sip trunk ***
destination-pattern 1..........
session protocol sipv2
session target sip-server
voice-class codec 1
dtmf-relay rtp-nte
no vad
sip-ua
authentication username 101146724 password 7 025F5C095E5F5D79151F
no remote-party-id
retry invite 2
retry register 10
retry options 3
timers connect 100
registrar dns:trunking.voipdnsservers.com expires 3600
sip-server dns:trunking.voipdnsservers.com
host-registrar
telephony-service
authentication credential Admin cisco
max-ephones 8
--More-- max-dn 99
ip source-address 192.168.2.1 port 2000
url services http://192.168.x.x/voiceview/common/login.do
url authentication http://192.168.x.x/CCMCIP/authenticate.asp
voicemail 2000
max-conferences 12 gain -6
web admin system name Admin password cisco
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp 7960 Jan 04 2015 12:01:16
ephone-dn 1 dual-line
number 1000
label "Anthony Sutherland"
description Anthony's extension
name Anthony Sutherland
call-forward busy 2000
call-forward noan 2000 timeout 18
hold-alert 30 originator
ephone-dn 2 dual-line
number 1001
label "Vickie Sutherland"
description Vickie's extension
name Vickie Sutherland
ephone 1
device-security-mode none
description "Anthony Sutherland's 1000 phone"
mac-address 001D.4596.17F6
username "Anthony" password cisco
type 7960
button 1:1
ephone 2
--More-- description "Vickie Sutherland's 2000 phone"
mac-address 001F.CA36.11E9
username "Vickie" password cisco
speed-dial 1 1000 label "Anthony"
type 7960
button 1:2
line con 0
line aux 0
line 194
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
exec-timeout 0 0
password ciscopress
login
scheduler allocate 20000 1000
ntp server 184.73.235.44
end
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#show runnno debug alldebug ccsip messages
SIP Call messages tracing is enabled
LAP_3825_1PORT#
Jan 8 14:57:57.679: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:trunking.voipdnsservers.com:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.100:5060;branch=z9hG4bK6E774
From: <sip:1000@trunking.voipdnsservers.com>;tag=30A5A0-2527
To: <sip:1000@trunking.voipdnsservers.com>
Date: Thu, 08 Jan 2015 14:57:57 GMT
Call-ID: 2F980FD8-968111E4-8002CB16-98DB8E00
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1420729077
CSeq: 53 REGISTER
Contact: <sip:1000@192.168.1.100:5060>
Expires: 3600
Supported: path
Content-Length: 0
Jan 8 14:57:57.747: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.100:5060;received=68.100.31.170;branch=z9hG4bK6E774;rport=62265
To: <sip:1000@trunking.voipdnsservers.com>;tag=aprqrttbei2-6gkqk110000a3
CSeq: 53 REGISTER
Contact: <sip:1000@192.168.1.100:5060>;expires=45
Jan 8 14:57:57.867: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:1001@192.168.1.100:5060 SIP/2.0
Via: SIP/2.0/UDP 208.73.146.93:5060;branch=z9hG4bK6aqbou3010mhagp8a6k0.1
Accept: application/sdp, application/isup, application/dtmf, application/dtmf-relay, multipart/mixed
Call-Id: pcst1420729078307423717210@192.168.201.117
Contact: <sip:5715357972@208.73.146.93:5060;transport=udp>
Content-Disposition: session; handling=required
Content-Length: 237
Content-Type: application/sdp
CSeq: 1 INVITE
From: "AVAYA GOVERNMEN" <sip:5715357972@192.168.101.117:5060;otg=TG_CORE_GSX;pstn-params=808482808882>;tag=gK04204cc2
In-Reply-To: 1006937118_12049738@207.155.147.62
Session-Expires: 1800;refresher=uas
Supported: timer
To: <sip:5713133270@192.168.101.100>
Max-Forwards: 70
v=0
o=Sonus_UAC 23050 8631 IN IP4 208.73.146.93
s=SIP Media Capabilities
c=IN IP4 208.73.146.93
t=0 0
m=audio 20234 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
Jan 8 14:57:57.879: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Call-ID: pcst1420729078307423717210@192.168.201.117
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Sent:
SIP/2.0 180 Ringing
To: <sip:5713133270@192.168.101.100>;tag=30A668-C57
CSeq: 1 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Contact: <sip:1001@192.168.1.100:5060>
Content-Length: 0
Jan 8 14:58:06.975: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Disposition: session;handling=required
Content-Length: 235
v=0
o=CiscoSystemsSIP-GW-UserAgent 0 2338 IN IP4 192.168.1.100
s=SIP Call
c=IN IP4 192.168.1.100
t=0 0
m=audio 17924 RTP/AVP 0 101
a=fmtp:101 0-16
Jan 8 14:58:07.075: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 235
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
Jan 8 14:58:07.087: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:1001@192.168.1.100:5060 SIP/2.0
Via: SIP/2.0/UDP 208.73.146.93:5060;branch=z9hG4bKsl4880205oegdjh306d1.1
Content-Length: 0
CSeq: 1 ACK
Max-Forwards: 70
Jan 8 14:58:07.171: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 0
CSeq: 1 ACK
Max-Forwards: 70
Jan 8 14:58:13.815: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:5715357972@208.73.146.93:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.1.100:5060;branch=z9hG4bK6F1E8C
From: <sip:5713133270@192.168.101.100>;tag=30A668-C57
To: "AVAYA GOVERNMEN" <sip:5715357972@192.168.101.117:5060;otg=TG_CORE_GSX;pstn-params=808482808882>;tag=gK04204cc2
Date: Thu, 08 Jan 2015 14:58:07 GMT
Max-Forwards: 70
Timestamp: 1420729093
CSeq: 101 BYE
Reason: Q.850;cause=16
Content-Length: 0
Jan 8 14:58:13.887: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.100:5060;received=68.100.31.170;branch=z9hG4bK6F1E8C;rport=62265
CSeq: 101 BYE
Content-Length: 0
Jan 8 14:58:16.071: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.1.100:5060;branch=z9hG4bK7016E0
From: <sip:1001@trunking.voipdnsservers.com>;tag=30ED78-ECB
To: <sip:1001@trunking.voipdnsservers.com>
Date: Thu, 08 Jan 2015 14:58:16 GMT
Call-ID: 2FFCC3E8-968111E4-8003CB16-98DB8E00
Max-Forwards: 70
Timestamp: 1420729096
CSeq: 53 REGISTER
Expires: 3600
Supported: path
Content-Length: 0
Jan 8 14:58:16.135: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.100:5060;received=68.100.31.170;branch=z9hG4bK7016E0;rport=62265
To: <sip:1001@trunking.voipdnsservers.com>;tag=aprqrttbei2-jihc4710000a3
CSeq: 53 REGISTER
Contact: <sip:1001@192.168.1.100:5060>;expires=46
LAP_3825_1PORT#debug ccsip messagesshow runn no debug all
All possible debugging has been turned off
LAP_3825_1PORT#
01-09-2015 03:48 PM
Heathrw,
did you get a chance to look at the RUNNING-CONF?
cheers,
Anthony
01-09-2015 04:18 PM
Hi Anthony,
The running config does not have any translations but the debugging is interesting. Not a setup I have seen before. and only had a brief chance to check it out.
It appears that your phone extensions are registering with your trunking provider as per the following from the debug:
What are numbers 5715357972 and 5713133270? The single number you mentioned that you have does not appear in any of the debugs.
The debug appears that 5715357972 rang 5713133270 and maybe the call landed on extension 1001, are you able to confirm any of this?
01-10-2015 06:26 AM
The 5715357972 = my cell phone;
The 5713133270 = DID # for SIP Trunk.
Yes my ISSUE: when I dial DID # 5713133270, how does it know to terminate to extension 1000? If 1000 is not active it terminates to my other
extension 1001; The SIP Provider has to be doing some translations somewhere. Like you say there is no translation in my Running-config.
Any ideas???
01-10-2015 07:24 PM
Attach the output of
show sip-ua register status
Turn on 'debug ccsip messasges' add the below config
sip-ua
credentials username 101146724 password 7 025F5C095E5F5D79151F realm trunking.voipdnsservers.com
Attach the output as possible changes
make another call into your system and attach the ccsip debug output
01-15-2015 05:23 PM
sorry for the delay....
Here is what i did:
BEFOR CHANGE:
LAP_3825_1PORT#show sip-ua register status
Line peer expires(sec) registered P-Associated-URI
1000 20001 53 yes
1001 20002 11 yes
LAP_3825_1PORT#
LAP_3825_1PORT#
ADDING:
sip-ua
Make call incoming call into CME:
RESULTS: call not complete; MSG: the wireless customer you are calling is not available please try again later.
01-15-2015 05:44 PM
Can you make a call from your Cisco phone to external
What is status after the change?
What is the output of the 'debug ccsip messages' when making a call in after the change?
01-15-2015 06:39 PM
Can you make a call from your Cisco phone to external? Yes
can not make incoming call into CME.
can originate calls from CME outgoing calls to external.
can not receive incoming calls into CME.
HERE GO: failed incoming call to CME
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#show runndialplan number 991111 en config tu all debug ccsip messagesgesterminal monitor
LAP_3825_1PORT#terminal monitorshow runn dialplan number 991111 en config tu all debug ccsip message
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
Jan 16 02:28:57.393: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.1.100:5060;branch=z9hG4bK3238F
From: <sip:101146724@trunking.voipdnsservers.com>;tag=12E310-42B
To: <sip:101146724@trunking.voipdnsservers.com>
Date: Fri, 16 Jan 2015 02:28:57 GMT
Call-ID: D65DCF1C-9C5D11E4-8022CA0F-335C7C00
Max-Forwards: 70
Timestamp: 1421375337
CSeq: 6 REGISTER
Contact: <sip:101146724@192.168.1.100:5060>
Expires: 3600
Supported: path
Content-Length: 0
Jan 16 02:28:57.473: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#
LAP_3825_1PORT#SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.100:5060;received=68.100.31.170;branch=z9hG4bK3238F;rport=6216
To: <sip:101146724@trunking.voipdnsservers.com>;tag=aprqrttbei2-ipb64a10000c0
CSeq: 6 REGISTER
Contact: <sip:101146724@192.168.1.100:5060>;expires=46
Jan 16 02:29:04.169: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:101146724@192.168.1.100:5060 SIP/2.0
Via: SIP/2.0/UDP 208.73.146.93:5060;branch=z9hG4bKn2384l100ofhmp1ap6p1.1
Call-Id: pcst14213753429072888275310@192.168.201.118
Content-Length: 238
CSeq: 1 INVITE
From: "AVAYA GOVERNMEN" <sip:5715357972@192.168.101.118:5060;otg=TG_CORE_GSX;pstn-params=808482808882>;tag=gK0e5afe94
In-Reply-To: 1007554466_48735224@207.155.147.62
Supported: timer
Max-Forwards: 70
v=0
o=Sonus_UAC 30485 20445 IN IP4 208.73.146.93
t=0 0
m=audio 32714 RTP/AVP 0 101
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
Jan 16 02:29:04.177: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Fri, 16 Jan 2015 02:29:04 GMT
Call-ID: pcst14213753429072888275310@192.168.201.118
CSeq: 1 INVITE
Content-Length: 0
Sent:
SIP/2.0 404 Not Found
To: <sip:5713133270@192.168.101.100>;tag=12FD8C-122A
CSeq: 1 INVITE
Content-Length: 0
Jan 16 02:29:04.261: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:101146724@192.168.1.100:5060 SIP/2.0
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
LAP_3825_1PORT#debug ccsip messageterminal monitor show runn
Jan 16 02:29:42.838: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.1.100:5060;branch=z9hG4bK33FED
From: <sip:1000@trunking.voipdnsservers.com>;tag=139494-218B
Date: Fri, 16 Jan 2015 02:29:42 GMT
Call-ID: 6CA3F7B9-9C6611E4-8002CA0F-335C7C00
Max-Forwards: 70
Timestamp: 1421375382
CSeq: 20 REGISTER
Expires: 3600
Supported: path
Content-Length: 0
Jan 16 02:29:42.918: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.100:5060;received=68.100.31.170;branch=z9hG4bK33FED;rport=6216
To: <sip:1000@trunking.voipdnsservers.com>;tag=aprqrttbei2-n7qi461000081
CSeq: 20 REGISTER
Contact: <sip:1000@192.168.1.100:5060>;expires=46
% Ambiguous command: "show ru"
LAP_3825_1PORT#u
Jan 16 02:29:46.130: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.1.100:5060;branch=z9hG4bK3489B
From: <sip:1001@trunking.voipdnsservers.com>;tag=13A170-0
Date: Fri, 16 Jan 2015 02:29:46 GMT
Call-ID: 6D09E418-9C6611E4-8003CA0F-335C7C00
Max-Forwards: 70
Timestamp: 1421375386
CSeq: 23 REGISTER
Expires: 3600
Supported: path
Content-Length: 0
Jan 16 02:29:46.210: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
allSIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.100:5060;received=68.100.31.170;branch=z9hG4bK3489B;rport=6216
To: <sip:1001@trunking.voipdnsservers.com>;tag=aprqrttbei2-ufeg3c00000e1
CSeq: 23 REGISTER
LAP_3825_1PORT#
01-15-2015 06:53 PM
So if you now enter 'num-exp 5713133270 1001' make a call to your system it should ring on 1001. And if 1001 is not connected the call should fail or go to voice mail.
If you are happy with that you may want to add a secondary line to each phone so it rings on all phones at once, see below.
no num-exp 5713133270 1001
num-exp 5713133270 1100
ephone-dn 3 octo
number 1100
label "Main Line"
description Main Line
name Main Line
ephone 1
button 1:1 2:3
restart
ephone 2
button 1:3 2:3
restart
let me know how you go
