need help for ACL and NAT for VoIP
trinhphanle
Dear experts
I configure my PBX server to work with one VoIP provider. When I put the server in blank network, mean that without VLANs.
The IP PBX server can register to the VoIP provider system normally and I can make call out and receive calls normally.
However, when I put the PBX behind the Cisco router with some configuration. The PBX cannot register with the VoIP provider system.
Eventhough I can receive calls from outside but can not make a call from inside to outside, because of the PBX cannot register.
Could you please help me to point out what is wrong with my Cisco router configuration.
Thanks a lot
Building configuration...
Current configuration : 1982 bytes
! Last configuration change at 17:18:27 UTC Mon Feb 24 2014
version 15.1
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$ZJEF$8np0QvQTD1nTaOosa9yGW1
no aaa new-model
memory-size iomem 20
no ipv6 cef
ip source-route
ip cef
license udi pid CISCO2911/K9 sn FTX1603AH9C
interface Embedded-Service-Engine0/0
no ip address
interface GigabitEthernet0/0
description internal-LAN
ip address x.x.x.4 255.255.0.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.1
encapsulation dot1Q 11
ip address 172.x.x.1 255.255.240.0
interface GigabitEthernet0/2
description internet
ip address 50.x.x.93 255.255.x.x
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 100 interface GigabitEthernet0/2 overload
ip nat inside source static udp x.x.x.8 5060 50.x.x.93 5060 extendable
ip route profile
ip route 0.0.0.0 0.0.0.0 50.x.x.94
ip route 172.16.240.0 255.255.x.0 x.x.x.5
ip route 172.16.242.0 255.255.x.0 x.x.x.5
access-list 100 permit ip x.x.0.0 0.0.255.255 any
access-list 100 permit ip 172.16.240.0 0.0.0.255 any
access-list 100 permit ip 172.16.242.0 0.0.0.255 any
access-list 100 permit udp any any range 5004 5090
access-list 100 permit udp any any range 10000 20000
control-plane
line con 0
8 Replies 8
Sreekanth Narayanan
I think you would be better off asking this question also in the NAT/ACL discussion boards since the Cisco router is not doing anything with respect to voice. It is only forwarding packets between the IP PBX and the provider.
Sorry for not being more useful
moataz_mamdouh
What do u mean by a blank network ?
I meant that when I put the PBX system to the network without VLANs, the IP PBX can register normally.
But if I put it into the network with router have NAT and ACLs. The PBX cannot register, eventhough everything is normal, users can access internet.
I can recieve calls, but the PBX cannot register with the VoIP provider system to make call out. And the provider cannot receive any packets from us.
moataz_mamdouh
What is the inside IP address of the PBX , is it behind giga 0/0 or gigs 0/1.1
If it is behind gi0/1.1 then you are missing ip nat inside under the subinterface
It is behind 0.0. And the NAT is correct. Users can go through internet normally, and we can call from outside to inside, but cannot call from in to out because of no registration between us and VoIP system provider.
Gordon Ross
Level 9
Level 9
You really don't want to use NAT with SIP. Odds are it won't work. This is because SIP embeds hostnames/IP Addresses inside the packets, and standard NAT does not look inside packets.
If you want a NAT-type functionality for SIP, you need something called a session border controller. Look up Cisco CUBE
http://www.cisco.com/c/en/us/products/unified-communications/unified-border-element/index.html
https://supportforums.cisco.com/docs/DOC-17964
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-border-element/99863-cube-config.html
GTG
Please rate all helpful posts.
Thanks for your help
Do you mean that I do not need to NAT for port 5060?
I will try.
