Need Help with corlist
muratg7777
Hi;
I am stuck with corlists. I want to configure;
When user "murat" dials 1..  he must use port 0/1/0
when user "muratc" dials 1..  he must use port 0/1/1
and goes on
My configuration seems correct but it is not working. Am I missing someting?
dial-peer cor custom
name murat
name ahmet
name zafer
name muratc
dial-peer cor list murat
member ahmet
member zafer
member muratc
dial-peer cor list zafer
member murat
member ahmet
member muratc
dial-peer cor list ahmet
member murat
member zafer
member muratc
dial-peer cor list muratc
member murat
member ahmet
member zafer
dial-peer voice 104 pots
corlist outgoing murat
destination-pattern 1..
port 0/1/0
forward-digits 0
dial-peer voice 105 pots
corlist outgoing muratc
port 0/1/1
forward-digits all
dial-peer voice 106 pots
corlist outgoing ahmet
port 0/1/2
forward-digits all
dial-peer voice 107 pots
corlist outgoing zafer
port 0/1/3
forward-digits all
Brandon Buffin
Do you have a cor applied to the ephone-dn for these users? If either incoming or outgoing dial peer (or ephone-dn in this case) does not have a cor applied, there will be no restriction on the call. You would need something like:
port010
port011
port012
port013
member port010
member port013
member port012
member port011
port 0/1/0
forward-digits 0
port 0/1/1
forward-digits all
port 0/1/2
forward-digits all
port 0/1/3
forward-digits all
ephone-dn 1
number 1234
cor incoming murat
ephone-dn 2
number 5678
cor incoming zafer
ephone-dn 3
number 2345
cor incoming ahmet
ephone-dn 4
number 6789
cor incoming zafer
See this link:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
You can also accomplish this with a combination of "answer-address" and voice translation rules. I think this solution is a little less complicated. See this link.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801bc341.shtml
Hope this helps.
Brandon
Brandon Buffin
port010
port011
port012
port013
member port010
member port013
member port012
member port011
port 0/1/0
forward-digits 0
port 0/1/1
forward-digits all
port 0/1/2
forward-digits all
port 0/1/3
forward-digits all
ephone-dn 1
number 1234
cor incoming murat
ephone-dn 2
number 5678
cor incoming zafer
ephone-dn 3
number 2345
cor incoming ahmet
ephone-dn 4
number 6789
cor incoming zafer
See this link:
Hope this helps.
Brandon
No I didn't assign corlist to ephone.
It worked now. Thanks
