04-23-2018 09:27 AM - edited 03-17-2019 12:40 PM
We had a CME - CUE integration that was working well. All pieces appear to be online.
I need assistance with when we dial the automated attendant as well as the voicemail pilot number, we get dead air, then a ring and then a busy.
We are getting some disconnect cause 41 messages and some SIP2.0/500 internal server error messages.
What can I generate and post that will be most helpful in isolating the issue?
Attached is my running config but it is long.
Solved! Go to Solution.
04-23-2018 11:05 AM
No clue why but reloading the module with
service-module inte 0/0 reload
fixed the issues - I can now put some hair back in my head.
Thanks All.
04-23-2018 09:30 AM
04-23-2018 09:34 AM
04-23-2018 11:05 AM
Thanks All.
04-23-2018 02:29 PM
04-24-2018 07:19 AM
I'm unsure if there was a power outage other than the system was moved (powered off - moved - powered on) and perhaps it never booted properly.
I'm happy though as it is working and was a bad day when it wasn't.
John
04-24-2018 07:29 AM
04-24-2018 07:38 AM
04-24-2018 07:51 AM
