07-19-2016
11:02 PM
- last edited on
03-25-2019
08:40 PM
by
ciscomoderator
Hi Guys,
I need a Router 2911 for Lab purpose under NFR. Wish to know if I can use it for CME, CUE (with additional module) and CUBE ?
Solved! Go to Solution.
07-20-2016 12:01 AM
You can definitely use this router for CME, CUE and CUBE functionality. Refer below:
http://www.cisco.com/c/en/us/products/routers/2911-integrated-services-router-isr/index.html
http://www.cisco.com/c/en/us/products/collateral/routers/2900-series-integrated-services-routers-isr/data_sheet_c78_553896.html
Deepak
07-20-2016 12:35 AM
Yes you can. For CME/CUE you need uk9 license along with cme-srst license. For CUBE, you can use it once you deploy uk9 license
07-20-2016 12:01 AM
Deepak
07-20-2016 05:35 AM
Thank you Deepak
07-20-2016 12:35 AM
07-20-2016 05:36 AM
Great, Thank you Mohammed !
