Need to downgrade firmware version on 8845 to get 3pcc functionality
JBilling215
We will be switching to a cloud solution but want to continue to use our exisitng cisco phones. 8845 and 8945 series. The problem is, it looks like 3pcc was only supported on lower firmware versions.
Active Load ID:sip8845_65.12-1-1-12
Inactive Load ID:sip8845_65.12-0-1SR1-1
Download Status:Failed
Requested Load ID:sip8845_65.11-2-3MSR1-1
Inactive Load Failure Reason
Internal Phone Error
Is there anyway to ac
Jaime Valencia
The process to go from Enterprise to 3PCC and viceversa is here
https://upgrade.cisco.com/
Depending on your contracts, there might be an associated cost.
java
if this helps, please rate
Jaime Valencia
java
That was the info i needed. Thanks
