The concept of "channels" is really not applicable to SIP trunks, they're just an IP to IP connectivity method which you can use, as long as you have enough BW to use it, or you configure a limit of calls, or something like that.
Most likely there's nothing you need to do in CUCM.
java
if this helps, please rate
