Network-clock synchronization PSTN
Thomas P
I have an issue to synchronize the network clock of my ISR 4321 with my operator.
Here is the configuration in place:
controller E1 0/1/0
 framing no-crc4
 clock source line primary
 pri-group timeslots 1-31
network-clock synchronization automatic
network-clock input-source 1 controller E1 0/1/0
The result of the show network-clock command:
There are no network clock sources configured
 Active source = UNAVAILABLE
 All Network Clock Configuration
 Priority  Clock Source             State                         Reason
 Current operating mode is Revertive
 Current OOR Switchover mode is Switchover
There are no slots disabled from participating in network clocking
Is there a command missing?
Thanks for your help.
Thomas.
29th Path code violations --- looks to be framing issue between you and service provider.
Please check with your service provide as framing issue can affect the clock syncronization.
20 Replies 20
Deepak Mehta
These two commands is configured on my set up and works good.
network-clock-select 1 {E1|T1}  0/1/0  -it will select which priority interface will be used for taking clock.
clock source line -  take the clock from the service the service prvoider.
Thanks you for your reply but these commands are not present on Cisco ISR 4321.
ah for 4300 series commands have changed a little.
The commands which you have applied are correct and you can also include below to synchronize individual channels.
network-clock synchronization participate slot / subslot
Below samples config
Sample Configuration
card type t1 0 2
card type t1 0 3
isdn switch-type primary-5ess
network-clock synchronization automatic >>>>>>>>>>>>>>>>>
network-clock synchronization participate 0/2>>>>>>>>>>>>>>>
voice-card 0/2
dsp services dspfarm
no watchdog
controller T1 0/2/0
framing esf
linecode b8zs
network-clock input-source 1 controller t1 0/2/0>>>>>>>>>>>>>>>>>>
cablelength long 0db
pri-group timeslots 1-24 voice-dsp
When I enter your command, I have the following:
Router(config)#network-clock synchronization participate 0/1
Slot 0 subslot 1 is already enabled for network clocking. Command Aborted.
Try " clock source network" first and see if it works.
Also try below inside the controller interface.Thanks
network-clock input-source 1 controller t1 0/1/0
The router doesn't accept the commands:
Router(config)#clock source network ?
% Unrecognized command
Router(config)#controller E1 0/1/0
Router(config-controller)#?
Controller configuration commands:
  ais-shut          Send LAIS when shutdown
  bert              Start BERT test
  channel-group     Specify the timeslots to channel-group mapping for an interface
  clock             Specify the clock source for a DS1 link
  default           Set a command to its defaults
  description       Controller specific description
  ds0-group         Configure group of timeslots to a particular signaling type
  exit              Exit from controller configuration mode
  framing           Specify the type of Framing on a E1 link
  help              Description of the interactive help system
  line-termination  Specify the line termination for E1
  linecode          Specify the line encoding method for a E1 link
  logging-events    LOG E1 Events
  loopback          Put the entire E1 line into loopback
  national          Set E1 National Reserve Bits.
  no                Negate a command or set its defaults
  pri-group         Configure the specified timeslots for PRI
  shutdown          Shut down a E1 link (send Blue Alarm)
  snmp              Modify SNMP controller parameters
  tdm-group         Configure DS0 group for TDM
  trunk-group       Configure interface to be in a trunk group
Here are the logs I see time to time:
Apr 20 17:26:36.975: %NETCLK-6-SRC_UPD: Synchronization source E1 0/1/0 status (Signal Failure clear) is posted to all selection process.
Apr 20 17:26:36.975: %NETCLK-6-SRC_UPD: Synchronization source E1 0/1/0 status (Critical Alarms clear) is posted to all selection process.
Apr 20 17:26:36.977: %NETCLK-6-SEL_CLOCK_SRC: Synchronization source E1 0/1/0 is selected by selection process(T0) to synchronize the system and generate T0 output.
You need to type the clock source command inside controller config.
What you have given isn't correct."Router(config)#clock source network ?"
Please go in controller config and then enter
Router(config)# controller t1 0/1/1
Router(config-controller)# clock source network
I entered your command:
Router(config-controller)#clock source network
This command replace the command clock source line primary I had before.
It doesn't seem to work better:
Router#sh network-clocks synchronization
Symbols:     En - Enable, Dis - Disable, Adis - Admin Disable
             NA - Not Applicable
             *  - Synchronization source selected
             #  - Synchronization source force selected
             &  - Synchronization source manually switched
Automatic selection process : Enable
Equipment Clock : 2048 (EEC-Option1)
Clock Mode : QL-Disable
ESMC : Disabled
SSM Option : 1
T0 : Internal
Hold-off (global) : 300 ms
Wait-to-restore (global) : 300 sec
Tsm Delay : 180 ms
Revertive : No
Nominated Interfaces
 Interface            SigType     Mode/QL      Prio  QL_IN  ESMC Tx  ESMC Rx
*Internal             NA          NA/Dis       251   QL-SEC    NA        NA
 E1 0/1/0             NA          NA/Dis       1     QL-FAILED NA        NA
With the clock source line primary command:
             NA - Not Applicable
ESMC : Disabled
SSM Option : 1
T0 : E1 0/1/0
Tsm Delay : 180 ms
Revertive : No
*E1 0/1/0             NA          NA/Dis       1     QL-SEC    NA        NA
Thank you for your help.
Try to bounce ( shut/no shut) the E1 controller .
Can you paste "sh controller e1"  output.Thank you
Following, the requested output:
Router#sh controllers E1 0/1/0
E1 0/1/0 is up.
  Applique type is Channelized E1 - balanced
  Description: *** E1/T2 SFR 3 ***
  No alarms detected.
  alarm-trigger is not set
  Framing is no-crc4, Line Code is HDB3, Clock Source is Network.
  International Bit: 1, National Bits: 11111
  Data in current interval (190 seconds elapsed):
     0 Line Code Violations, 29 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     28 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Hi Thomas,
Do you get the below command under controller ?
network-clock input-source priority controller [t1|e1] slot/bay/port
can u share show inventory /show diag?
regds,
aman
I can't enter this command:
Router(config-controller)#network-clock input-source priority controller E1 0/1/0
% Invalid input detected at '^' marker.
Attached, the requested show commands.
Hi Thomas,
I was just referring this link where the command is appearing. even link says
"When the NIM is used for voice applications, all voice T1/E1s have to be synchronized to a single clock source and any difference in clocks risk clock slips or interface flaps"
What is show version of router?
http://www.cisco.com/c/en/us/support/docs/routers/4000-series-integrated-services-routers/118792-config-isr-00.html
card type { t1 | e1 } slot subslot
voice-card slot
   codec complexity { flex [ reservation-fixed { high | medium }]
| high | medium | secure }
controller { t1 | e1 } slot / subslot / port
   framing {sf | esf}
   or
   framing {crc4 | no-crc4}
   linecode {ami | b8zs}
   or
   linecode { ami | hdb3 }
   pri-group timeslots timeslot-range [ nfas_d | service ][voice-dsp]
regds,
aman
