network out of order (38)
Sharin Taib
Hi all
been trying to troubleshoot this one particular phone that is having an issue. Currently on the "voice router", 4 FXO ports are connected and pointed to the same "voice gateway". this is the error that i see on the dial-peer
        Time elapsed since last clearing of voice call statistics never
        Connect Time = 2997, Charged Units = 0,
        Successful Calls = 191, Failed Calls = 169, Incomplete Calls = 0
        Accepted Calls = 32, Refused Calls = 0,
        Last Disconnect Cause is "26  ",
        Last Disconnect Text is "network out of order (38)",
from what I have seen, the configuration on both router and gateway seems to be matching each other.
I have also done a cross-match with the other 3 working POTS and found that they all are similar in the way that it's configured.
But i am still dumb-founded as to why I am getting this error.
Is there anything particular that I am missing?
6 Replies 6
keithknowles
Can you post your voice router config (save for any private information).
Hi, these are the voice related on the voice router
voice-card 0
no dspfarm
voice rtp send-recv
voice service voip
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
interface Serial0/0/0
  bandwidth 256
ip address 202.80.100.100 255.255.255.252
ip nat outside
ip virtual-reassembly
load-interval 30
no keepalive
no fair-queue
serial restart-delay 0
h323-gateway voip interface
h323-gateway voip bind srcaddr 202.80.100.100
voice-port 0/2/0
timeouts interdigit 3
station-id number 614
caller-id enable
voice-port 0/2/1
station-id number 615
caller-id enable
dial-peer voice 10 voip
destination-pattern .T
voice-class codec 1
session target ipv4:10.10.255.10
ip qos dscp cs5 media
dial-peer voice 5 pots
description *** Vessel 12345678 ***
destination-pattern 12345678
port 0/2/0
dial-peer voice 6 pots
description *** Vessel  87654321 ***
destination-pattern 87654321
port 0/2/1
card-type is not configure
the D Channel is not also configure in your configuration.
and "isdn primary-ini will need to be configure on the D channel
"isdn incoming--voice voice is also needed in you config
Hi Rammany,
the card has 4 ports, 3 of them are working fine. changing the card type would affect the whole card, yes?
and does the D channel needed to be configured when the other ports are working?
what type of card are you using?  is it FXO or T1/E1?
4 x FXO ports on a single card, as indicated earlier.
