Network port
monica.diaz08
I have a 7940 series phone and I have tried to use the PC network port and my computer is not working. It just doesn't give me an IP address to the computer.
2 Accepted Solutions
Jaime Valencia
Is the port enabled??
Do you have the proper config in your switch for that to happen??
java
if this helps, please rate
Suresh Hudda
Can you check PC port setting on IP phone configuration page in CUCM (in case of CME you can create a phone template), it should be enabled.
Suresh
5 Replies 5
Jaime Valencia
java
I have solved. The port was unable.
Suresh Hudda
Suresh
Yes, thank you that was what I did.
Hi Monica, u can mark this post as Answered..it will help others.
Suresh
