Network ports for MOH?
shikamarunara
Level 4
Level 4
I need to find which network ports to open on an ACL to allow MOH to pass through.  Currently, on our wireless network, I am able to route RTP properly between endpoints, but MOH can not be heard (MOH is configured properly, it works fine on the wired infrustructure).  We are using unicast.
phooghen
MoH is just RTP traffic but in one direction i.e. from MoH source to the phone. Therefore opening RTP ports should be enough (16384 - 32767 / UDP)
Which codec do you use on the Wireless ?
If you have different codec type, you need transcoders resources.
Pierre.
G711 and G729 are the only codecs used, G711 for MOH.  However, never heard of a need to asdjust wireless for this consideration.  RTP can be handled between phone endpoints, but I guess a good place to look for any ACL issue is whether UDP 16384 - 32767 is allowed between the MOH server and a wireless phone.
