Newbie. SIP trunking entre Cisco 2851 y Asterisk.
storesnay
He de realizar un sip trunking entre el equipo que seguidamente listo y Asterisk y me gustaria saber si para realizarlo tengo suficiente con este equipo o se ha de adquirir algun modulo/licencia para realizarlo.
Por otra parte tambien me gustaria saber si hay alguna documentación donde me explique como hacerlo.
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(15)T9, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Tue 28-Apr-09 13:10 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
CENTTEL uptime is 38 weeks, 6 days, 14 hours, 58 minutes
System restarted at 17:50:25 Bcn-Estiu Fri Aug 26 2011
System image file is "flash:c2800nm-spservicesk9-mz.124-15.T9.bin"
Cisco 2851 (revision 53.51) with 243712K/18432K bytes of memory.
Processor board ID FHK1337F2XM
2 Gigabit Ethernet interfaces
31 Serial interfaces
2 Serial(sync/async) interfaces
1 terminal line
1 Channelized E1/PRI port
1 cisco Integrated Service Engine(s)
   Cisco Unity Express 7.0.3 in slot 1
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
un saludo
paolo bevilacqua
Yes, it can be done.
You can read documentaiotn or search this forum. Alternatively hire someone with experience for sure and quick results.
Thank's a lot.
You're welcome, please remember to rate useful posts clicking on the stars below.
FYI, there's a spanish CSC section
https://supportforums.cisco.com/community/spanish
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
