NME-Cue Service module
shawn.lewis
Hi There
We have replaced a faulty router with a Cisco 2851 router today and we are having problems with the NME-CUE service module.
Current config on router for the NME_CUE
interface Integrated-Service-Engine1/0
ip unnumbered GigabitEthernet0/0.11
service-module ip address 10.128.139.253 255.255.255.0
service-module ip default-gateway 10.128.139.254
no keepalive
ip route 0.0.0.0 0.0.0.0 10.129.253.185
ip route 10.128.139.253 255.255.255.255 Integrated-Service-Engine1/0
sh interfaces integrated-Service-Engine 1/0
Integrated-Service-Engine1/0 is up, line protocol is up
  Hardware is BCM5703, address is 0021.d8d2.a070 (bia 0021.d8d2.a070)
  Interface is unnumbered. Using address of GigabitEthernet0/0.11 (10.128.139.254)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is force-up, media type is internal
  output flow-control is XON, input flow-control is XON
  Last input never, output 00:00:54, output hang never
  Queueing strategy: fifo
  Output queue: 0/512 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 0 multicast, 0 pause input
     116 packets output, 32607 bytes, 0 underruns
     0 output errors, 0 collisions, 7 interface resets
     0 lost carrier, 0 no carrier, 0 pause output
service-module integrated-Service-Engine 1/0 sess
Trying 10.128.139.254, 2066 ... Open
CCCC
                           FIRST NATIONAL BANK Premier Banking Westway
       This device belongs to the FirstRand Group of Companies ("FirstRand")
       Only persons with permission are allowed to access and/or use this
       device. FirstRand reserves the right to intercept and/or monitor the
       use of this device. By accessing this device you waive any expectation
       to privacy. FirstRand reserves the right to institute civil or
       criminal legal action against any person that does or attempts to
       access/use its device without permission and/or do any of the acts
       prohibited by local and international law. Without derogating from
       any of the foregoing, the FirstRand Group Policy for acceptable use
       of information systems applies to your use of this device.
username: f2125005nssh
password:
no keepalive
When I do a "service-module integrated-Service-Engine 1/0 status" i get the following
Service Module is Cisco Integrated-Service-Engine1/0
Service Module supports session via TTY line 66
Service Module is trying to recover from reset/shutdown
Service Module status is not available
  Keepalive not set
  IP interface brief
In1/0                      10.128.139.254  YES TFTP   up                    up
When I logon to the service I cannot get past the password fieled. It just hangs even after i hit the enter button a few times.
password:
paolo bevilacqua
It may have a corrputed image and need re-installation from boot loader.
Much appreciated. I have managed to sort out by doing a shutdown, removed the module from the router, powered up the router without the unit and let the router run for five minutes, Switched off the router and installed the module. The router and the module came back up with no issues.
