08-15-2013 01:05 PM - edited 03-16-2019 06:53 PM
Dear all,
does anybody can tell me which side the problem is telco or mine who is disconnecting the call. i am trying to make a international call by using access code as 97 but i can not hear any ring on the other side but the timer starts on the phone. the below dialpeer is configured.cucm 8.5 3945h323 gateway with fxo ports connected with analog trunks.
dial-peer voice 97 pots
corlist outgoing International
description International-Line
destination-pattern 97.T
port 1/0/1
009426: Aug 14 11:34:10.346: //2656488/00E02069381E/CCAPI/cc_api_caps_ind:
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=250(ms), Fax Nom=300(ms))
009427: Aug 14 11:34:10.346: //2656488/00E02069381E/CCAPI/cc_api_caps_ack:
Destination Interface=0x6652D3A0, Destination Call Id=2656489, Source Call Id=2656488,
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Vad=OFF(0x1),
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=4604)
009428: Aug 14 11:34:10.346: //2656489/00E02069381E/CCAPI/cc_api_caps_ack:
Destination Interface=0x6597616C, Destination Call Id=2656488, Source Call Id=2656489,
009429: Aug 14 11:34:10.346: //2656489/00E02069381E/CCAPI/cc_api_voice_mode_event:
Call Id=2656489
009430: Aug 14 11:34:10.346: //2656489/00E02069381E/CCAPI/cc_api_voice_mode_event:
Call Entry(Context=0x64916AB8)
009431: Aug 14 11:34:10.722: //-1/802A7E6E1600/DPM/dpAssociateIncomingPeerCore:
Calling Number=38555, Called Number=9700919848647605, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
009432: Aug 14 11:34:10.722: //-1/802A7E6E1600/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=8000
009433: Aug 14 11:34:10.722: //-1/802A7E6E1600/DPM/dpAssociateIncomingPeerCore:
Calling Number=38555, Called Number=9700923016647605, Voice-Interface=0x0,
009434: Aug 14 11:34:10.722: //-1/802A7E6E1600/DPM/dpAssociateIncomingPeerCore:
009435: Aug 14 11:34:10.722: //-1/802A7E6E1600/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=secretary
----- ccCallInfo IE subfields -----
cisco-ani=38555
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=9700919848647605
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1
009436: Aug 14 11:34:10.722: //-1/802A7E6E1600/CCAPI/cc_api_call_setup_ind_common:
Interface=0x6597616C, Call Info(
Calling Number=38555(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=9700919848647605(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subsriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=8000, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=2656490
009437: Aug 14 11:34:10.722: //-1/802A7E6E1600/CCAPI/ccCheckClipClir:
In: Calling Number=38555(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
009438: Aug 14 11:34:10.722: //-1/802A7E6E1600/CCAPI/ccCheckClipClir:
Out: Calling Number=38555(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
009439: Aug 14 11:34:10.722: //2656490/802A7E6E1600/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=38555(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=9700919848647605(TON=Unknown, NPI=Unknown))
009440: Aug 14 11:34:10.722: //2656490/802A7E6E1600/CCAPI/cc_process_call_setup_ind:
Event=0x65AD2150
009441: Aug 14 11:34:10.722: //2656490/802A7E6E1600/CCAPI/ccCallSetContext:
Context=0x66AC4548
009442: Aug 14 11:34:10.722: //2656490/802A7E6E1600/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 2656490 with tag 8000 to app "Default"
009443: Aug 14 11:34:10.722: //2656490/802A7E6E1600/CCAPI/ccCallProceeding:
009444: Aug 14 11:34:10.722: //-1/802A7E6E1600/DPM/dpMatchPeersCore:
Calling Number=, Called Number=9700923016647605, Peer Info Type=DIALPEER_INFO_SPEECH
009445: Aug 14 11:34:10.722: //-1/802A7E6E1600/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=9700923016647605
009446: Aug 14 11:34:10.726: //-1/802A7E6E1600/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
009447: Aug 14 11:34:10.726: //-1/802A7E6E1600/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=97
2: Dial-peer Tag=200
009448: Aug 14 11:34:10.726: //2656490/802A7E6E1600/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=97, Allow TDM Hairpin=TRUE, Params=0x649F30F4,
009449: Aug 14 11:34:10.726: //2656490/802A7E6E1600/CCAPI/ccCheckClipClir:
009450: Aug 14 11:34:10.726: //2656490/802A7E6E1600/CCAPI/ccCheckClipClir:
009451: Aug 14 11:34:10.726: //2656490/802A7E6E1600/CCAPI/ccCallSetupRequest:
Destination Pattern=97.T, Called Number=9700919848647605, Digit Strip=TRUE
009452: Aug 14 11:34:10.726: //2656490/802A7E6E1600/CCAPI/ccCallSetupRequest:
Redirect Number=, Display Info=
Account Number=secretary, Final Destination Flag=TRUE,
Guid=802A7E6E-326B-B120-1600-DA020A81102E, Outgoing Dial-peer=97
009453: Aug 14 11:34:10.726: //2656490/802A7E6E1600/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-ani=38555
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
009454: Aug 14 11:34:10.726: //2656490/802A7E6E1600/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x65B3A598, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=38555(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=9700919848647605(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subsriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=97, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
009455: Aug 14 11:34:10.726: //2656491/802A7E6E1600/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
009456: Aug 14 11:34:10.726: //2656491/802A7E6E1600/CCAPI/ccCallSetContext:
Context=0x649F30A4
009457: Aug 14 11:34:10.726: //2656490/802A7E6E1600/CCAPI/ccSaveDialpeerTag:
009458: Aug 14 11:34:10.726: //2656490/802A7E6E1600/CCAPI/ccSaveDialpeerTag:
009459: Aug 14 11:34:10.726: //2656491/802A7E6E1600/CCAPI/cc_api_call_proceeding:
Interface=0x65B3A598, Progress Indication=NULL(0)
009460: Aug 14 11:34:10.726: //2656491/802A7E6E1600/CCAPI/ccSaveDialpeerTag:
009461: Aug 14 11:34:10.726: //2656490/802A7E6E1600/CCAPI/ccSaveDialpeerTag:
009462: Aug 14 11:34:15.138: //2656491/802A7E6E1600/CCAPI/cc_api_call_cut_progress:
Interface=0x65B3A598, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
Cause Value=0
009463: Aug 14 11:34:15.138: //2656491/802A7E6E1600/CCAPI/cc_api_call_cut_progress:
Call Entry(Responsed=TRUE)
009464: Aug 14 11:34:15.138: //2656490/802A7E6E1600/CCAPI/ccCallCutProgress:
Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
Voice Call Send Alert=FALSE, Call Entry(AlertSent=FALSE)
009465: Aug 14 11:34:15.142: //2656490/802A7E6E1600/CCAPI/ccCallCutProgress:
009466: Aug 14 11:34:15.142: //2656491/802A7E6E1600/CCAPI/cc_api_get_called_ccm_detected:
CallInfo(ccm detected=0)
009467: Aug 14 11:34:15.142: //2656491/802A7E6E1600/CCAPI/ccSaveDialpeerTag:
009468: Aug 14 11:34:15.142: //2656490/802A7E6E1600/CCAPI/ccSaveDialpeerTag:
009469: Aug 14 11:34:15.142: //2656490/802A7E6E1600/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
Tone Direction=Network, Params=0x0, Call Id=2656490
009470: Aug 14 11:34:15.142: //2656490/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x66AB5BD0, callID1=0x2888EA, callID2=0x2888EB, tag=0x0)
009471: Aug 14 11:34:15.142: //2656490/802A7E6E1600/CCAPI/ccConferenceCreate:
Conference Id=0x66AB5BD0, Call Id1=2656490, Call Id2=2656491, Tag=0x0
009472: Aug 14 11:34:15.142: //2656490/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
009473: Aug 14 11:34:15.142: cc_api_get_xcode_stream : 4164
009474: Aug 14 11:34:15.142: //2656490/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0xE17A1, Source Interface=0x6597616C, Source Call Id=2656490,
Destination Call Id=2656491, Disposition=0x0, Tag=0x0
009475: Aug 14 11:34:15.142: //2656490/802A7E6E1600/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0xE17A1, Destination Call Id=2656491)
009476: Aug 14 11:34:15.142: //2656491/802A7E6E1600/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0xE17A1, Destination Call Id=2656490)
009477: Aug 14 11:34:15.142: //2656491/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0xE17A1, Source Interface=0x65B3A598, Source Call Id=2656491,
Destination Call Id=2656490, Disposition=0x0, Tag=0x0
009478: Aug 14 11:34:15.142: //2656490/802A7E6E1600/CCAPI/cc_generic_bridge_done:
009479: Aug 14 11:34:15.142: //2656491/802A7E6E1600/CCAPI/cc_api_caps_ind:
Destination Interface=0x6597616C, Destination Call Id=2656490, Source Call Id=2656491,
Caps(Codec=0x6EFFF, Fax Rate=0xFF, Vad=0x3,
Modem=0x2, Codec Bytes=0, Signal Type=3)
009480: Aug 14 11:34:15.142: //2656491/802A7E6E1600/CCAPI/cc_api_caps_ind:
009481: Aug 14 11:34:15.142: //2656490/802A7E6E1600/CCAPI/cc_process_notify_bridge_done:
Conference Id=0xE17A1, Call Id1=2656490, Call Id2=2656491
009482: Aug 14 11:34:15.154: //2656490/802A7E6E1600/CCAPI/cc_api_caps_ind:
Destination Interface=0x65B3A598, Destination Call Id=2656491, Source Call Id=2656490,
Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Modem=0x2, Codec Bytes=160, Signal Type=2)
009483: Aug 14 11:34:15.154: //2656490/802A7E6E1600/CCAPI/cc_api_caps_ind:
009484: Aug 14 11:34:15.154: //2656490/802A7E6E1600/CCAPI/cc_api_caps_ack:
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=4415)
009485: Aug 14 11:34:15.154: //2656491/802A7E6E1600/CCAPI/cc_api_caps_ack:
009486: Aug 14 11:34:15.154: //2656491/802A7E6E1600/CCAPI/cc_api_voice_mode_event:
Call Id=2656491
009487: Aug 14 11:34:15.154: //2656491/802A7E6E1600/CCAPI/cc_api_voice_mode_event:
Call Entry(Context=0x649F30A4)
009488: Aug 14 11:34:15.158: //2656491/802A7E6E1600/CCAPI/cc_api_call_connected:
Interface=0x65B3A598, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
Connection Handle=0
009489: Aug 14 11:34:15.158: //2656491/802A7E6E1600/CCAPI/cc_api_call_connected:
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
009490: Aug 14 11:34:15.158: //2656490/802A7E6E1600/CCAPI/ccCallConnect:
Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
009491: Aug 14 11:34:15.158: //2656491/802A7E6E1600/CCAPI/cc_api_get_called_ccm_detected:
009492: Aug 14 11:34:15.158: //2656490/802A7E6E1600/CCAPI/ccCallConnect:
Call Entry(Connected=TRUE, Responsed=TRUE)
009493: Aug 14 11:34:15.158: //2656491/802A7E6E1600/CCAPI/ccSaveDialpeerTag:
Incoming Dial-peer=0
009494: Aug 14 11:34:15.158: //2656490/802A7E6E1600/CCAPI/ccSaveDialpeerTag:
Outgoing Dial-peer=0
009495: Aug 14 11:34:15.158: //2656491/802A7E6E1600/CCAPI/ccSaveDialpeerTag:
009496: Aug 14 11:34:15.158: //2656490/802A7E6E1600/CCAPI/ccSaveDialpeerTag:
009497: Aug 14 11:34:37.155: //2656488/00E02069381E/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x649D9F68, Call Id=2656488
009498: Aug 14 11:34:37.155: //2656488/00E02069381E/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
009499: Aug 14 11:34:37.155: //2656488/00E02069381E/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
009500: Aug 14 11:34:37.155: //2656488/00E02069381E/CCAPI/ccConferenceDestroy:
Conference Id=0xE17A0, Tag=0x0
009501: Aug 14 11:34:37.155: //2656488/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Conference Id=0xE17A0, Source Interface=0x6597616C, Source Call Id=2656488,
Destination Call Id=2656489, Disposition=0x0, Tag=0x0
009502: Aug 14 11:34:37.155: //2656489/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Conference Id=0xE17A0, Source Interface=0x6652D3A0, Source Call Id=2656489,
Destination Call Id=2656488, Disposition=0x0, Tag=0x0
009503: Aug 14 11:34:37.155: //2656488/00E02069381E/CCAPI/cc_generic_bridge_done:
009504: Aug 14 11:34:37.155: //2656489/00E02069381E/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=2656489
009505: Aug 14 11:34:37.155: //2656489/00E02069381E/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
009506: Aug 14 11:34:37.155: //2656489/00E02069381E/CCAPI/ccCallDisconnect:
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
009507: Aug 14 11:34:37.155: //2656489/00E02069381E/CCAPI/cc_api_get_transfer_info:
009508: Aug 14 11:34:37.251: //2656489/00E02069381E/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x6652D3A0, Tag=0x0, Call Id=2656489,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
009509: Aug 14 11:34:37.251: //2656489/00E02069381E/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
009510: Aug 14 11:34:37.251: //2656488/00E02069381E/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
009511: Aug 14 11:34:37.251: //2656488/00E02069381E/CCAPI/ccCallDisconnect:
009512: Aug 14 11:34:37.251: //2656488/00E02069381E/CCAPI/cc_api_get_transfer_info:
009513: Aug 14 11:34:37.251: //2656488/00E02069381E/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x649D9F68, Tag=0x0, Call Id=2656488,
009514: Aug 14 11:34:37.251: //2656488/00E02069381E/CCAPI/cc_api_call_disconnect_done:
009515: Aug 14 11:34:38.495: //2656486/3A7E8791839D/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x66563E7C, Call Id=2656486
009516: Aug 14 11:34:38.495: //2656486/3A7E8791839D/CCAPI/cc_api_call_disconnected:
009517: Aug 14 11:34:38.495: //2656487/3A7E8791839D/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=2656487
009518: Aug 14 11:34:38.495: //2656487/3A7E8791839D/CCAPI/ccCallDisconnect:
009519: Aug 14 11:34:38.495: //2656487/3A7E8791839D/CCAPI/ccCallDisconnect:
009520: Aug 14 11:34:38.495: //2656487/3A7E8791839D/CCAPI/cc_api_get_transfer_info:
009521: Aug 14 11:34:38.495: //2656486/3A7E8791839D/CCAPI/ccCallDisconnect:
009522: Aug 14 11:34:38.495: //2656486/3A7E8791839D/CCAPI/ccCallDisconnect:
009523: Aug 14 11:34:38.495: //2656486/3A7E8791839D/CCAPI/cc_api_get_transfer_info:
009524: Aug 14 11:34:40.495: //2656486/3A7E8791839D/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x66563E7C, Tag=0x0, Call Id=2656486,
009525: Aug 14 11:34:40.495: //2656486/3A7E8791839D/CCAPI/cc_api_call_disconnect_done:
009526: Aug 14 11:34:40.495: //2656487/3A7E8791839D/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x663E6FB8, Tag=0x0, Call Id=2656487,
009527: Aug 14 11:34:40.495: //2656487/3A7E8791839D/CCAPI/cc_api_call_disconnect_done:
009528: Aug 14 11:34:43.371: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=, Called Number=, Voice-Interface=0x66563E7C,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
009529: Aug 14 11:34:43.371: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_PORT; Incoming Dial-peer=100
009530: Aug 14 11:34:47.715: //2656484/80B4CD5D371E/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x649421A8, Call Id=2656484
009531: Aug 14 11:34:47.715: //2656484/80B4CD5D371E/CCAPI/cc_api_call_disconnected:
009532: Aug 14 11:34:47.715: //2656484/80B4CD5D371E/CCAPI/cc_api_get_transfer_info:
009533: Aug 14 11:34:47.715: //2656484/80B4CD5D371E/CCAPI/ccConferenceDestroy:
Conference Id=0xE179F, Tag=0x0
009534: Aug 14 11:34:47.715: //2656484/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Conference Id=0xE179F, Source Interface=0x6597616C, Source Call Id=2656484,
Destination Call Id=2656485, Disposition=0x0, Tag=0x0
009535: Aug 14 11:34:47.715: //2656485/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Conference Id=0xE179F, Source Interface=0x6652D3A0, Source Call Id=2656485,
Destination Call Id=2656484, Disposition=0x0, Tag=0x0
009536: Aug 14 11:34:47.715: //2656484/80B4CD5D371E/CCAPI/cc_generic_bridge_done:
009537: Aug 14 11:34:47.715: //2656484/80B4CD5D371E/CCAPI/ccCallDisconnect:
009538: Aug 14 11:34:47.715: //2656484/80B4CD5D371E/CCAPI/ccCallDisconnect:
009539: Aug 14 11:34:47.715: //2656484/80B4CD5D371E/CCAPI/cc_api_get_transfer_info:
009540: Aug 14 11:34:47.715: //2656485/80B4CD5D371E/CCAPI/ccCallDisconnect:
009541: Aug 14 11:34:47.715: //2656485/80B4CD5D371E/CCAPI/ccCallDisconnect:
009542: Aug 14 11:34:47.715: //2656485/80B4CD5D371E/CCAPI/cc_api_get_transfer_info:
009543: Aug 14 11:34:47.715: //2656484/80B4CD5D371E/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x649421A8, Tag=0x0, Call Id=2656484,
009544: Aug 14 11:34:47.715: //2656484/80B4CD5D371E/CCAPI/cc_api_call_disconnect_done:
009545: Aug 14 11:34:47.715: //2656485/80B4CD5D371E/CCAPI/ccSaveDialpeerTag:
009546: Aug 14 11:34:47.827: //2656485/80B4CD5D371E/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x6652D3A0, Tag=0x0, Call Id=2656485,
009547: Aug 14 11:34:47.827: //2656485/80B4CD5D371E/CCAPI/cc_api_call_disconnect_done:
08-15-2013 01:36 PM
The timers starts always no matter what.
You can use a reguar phone to test the phone line;.
