NO Audio During consultative transfer
Yenosh
Hi All,
When so consultative call transfer, call is getting connected but there is no audio on both ends. We have collected call manager logs and did not find any signaling issue.
I can only See, leg 1 is using PCMU and transferred leg is using PCMA. Is it causing the problem.
Tirtha Tripathy
It might be invoking Transcoder/MTP for codec difference between A leg and B leg of the call and might not be releasing it post-transfer.
Check both IP Phones webpage and the stream of 'connected call' connected to which remote IP address \ codec \ receive and send packets
Might have to check on Phone/MTP/CUCM
- TT
Regards, Tirtha
The main reason behind it is codec mismatch between the MTP and trunk. MTP supports only G711U-law but in sdp coming from sbc contains only A-law.
So we have suggested SBC team to advertise both A-law and U-law it fixes the issue
