No audio on incoming call with CFA, CME, SIP trunk
alig.norbert
Level 4
Level 4
Hi there
I'm facing the following problem:
CME 8.6 (ipvoice-mz.151-4.M10.bin) with a SIP trunk box behind an ASA (8.2.5).
CME -> Patton-SN5300 SIP provider box -> Cisco ASA -> SIP-Provider.
Problem:
I have no audio when an external incoming call to an internal number with CFA to an external number through the SIP trunk. Signalling is fine, it's ringing on the final number, but no audio.
External IN/OUT SIP trunk calls works fine as well consult transfer from an external incoming call to an external destination.
What I have already tried:
With "media flow-through" I see the RTP stream (show voip rtp connection). With "media flow-around" ther is no RTP stream shown.
SIP inspection is disabled on the ASA. Tried fixing the codec -> still no audio.
Any ideas? NAT'ing on the ASA?
Kind regards,
Norbert
Here the config:
voice service voip
 ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 redirect ip2ip
 fax-relay ans-disable
 h323
  h245 caps mode restricted
 sip
  asserted-id ppi
voice class codec 1
 codec preference 1 g711alaw
 codec preference 2 g729r8
 codec preference 3 g729br8
 codec preference 4 g711ulaw
 codec preference 5 g723r63
 codec preference 6 g723ar63
voice translation-rule 40
 rule 1 /\(.*\)/ /0\1/
voice translation-rule 190
 rule 1 /^0\(.*\)/ /\1/
voice translation-rule 191   <- internal to external map
 rule 1 /^201/ /xxxxxxxx19/
 rule 2 /^202/ /xxxxxxxx18/
 rule 15 /^0\(.*\)/ /\1/
voice translation-rule 192  <- external to internal map
 rule 2 /^xxxxxxxx19/ /201/
 rule 3 /^xxxxxxxx18/ /202/
voice translation-profile TP_IN_SIP
 translate calling 40
 translate called 192
voice translation-profile TP_OUT_SIP
 translate calling 191
 translate called 190
dial-peer voice 2001 voip
 description *** SIP-TRUNK (OUT) ***
 translation-profile incoming TP_IN_SIP
 translation-profile outgoing TP_OUT_SIP
 destination-pattern 0.T
 session protocol sipv2
 session target ipv4:192.168.1.10:5062
 session transport udp
 incoming called-number .
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
sip-ua
 credentials username xxxxxx password 7 xxxxxx realm 192.168.1.10:5062 <- IP Patton box
 keepalive target ipv4:192.168.1.10:5062
 authentication username xxxx password 7 xxx
 retry invite 2
 retry response 2
 retry bye 2
 retry register 2
 retry options 1
 registrar ipv4:192.168.1.10:5062 expires 60
show voip rtp connections:
No. CallId     dstCallId  LocalRTP RmtRTP     LocalIP                                RemoteIP
1     2201       2202       18182    6542     192.168.1.1                          192.168.1.10
2     2202       2201       17354    6544     192.168.1.1                          192.168.1.10
Found 2 active RTP connections
show  sip-ua calls:
Total SIP call legs:2, User Agent Client:1, User Agent Server:1
SIP UAC CALL INFO
Call 1
SIP Call ID                : B537765A-F4F311E4-83AAF7BA-53BC2227@192.168.1.1
   State of the call       : STATE_ACTIVE (7)
   Substate of the call    : SUBSTATE_NONE (0)
   Calling Number          : xxxxxxxx22
   Called Number           : xxxxxxxx75
   Bit Flags               : 0xC04018 0x50000100 0x0
   CC Call ID              : 2207
   Source IP Address (Sig ): 192.168.1.1
   Destn SIP Req Addr:Port : [192.168.1.10]:5062
   Destn SIP Resp Addr:Port: [192.168.1.10]:5062
   Destination Name        : 192.168.1.10
   Number of Media Streams : 1
   Number of Active Streams: 1
   RTP Fork Object         : 0x0
   Media Mode              : flow-through
   Media Stream 1
     State of the stream      : STREAM_ACTIVE
     Stream Call ID           : 2207
     Stream Type              : voice+dtmf (1)
     Stream Media Addr Type   : 1
     Negotiated Codec         : g711alaw (160 bytes)
     Codec Payload Type       : 8
     Negotiated Dtmf-relay    : rtp-nte
     Dtmf-relay Payload Type  : 101
     QoS ID                   : -1
     Local QoS Strength       : BestEffort
     Negotiated QoS Strength  : BestEffort
     Negotiated QoS Direction : None
     Local QoS Status         : None
     Media Source IP Addr:Port: [192.168.1.1]:16670
     Media Dest IP Addr:Port  : [192.168.1.10]:6552
Options-Ping    ENABLED:NO    ACTIVE:NO
   Number of SIP User Agent Client(UAC) calls: 1
SIP UAS CALL INFO
Call 1
SIP Call ID                : 7f04a2619ca33575
   Called Number           : xxxxxxxx18
   Bit Flags               : 0xC0401E 0x18000100 0x4
   CC Call ID              : 2206
   Media Stream 1
     Stream Call ID           : 2206
     Stream Type              : voice+dtmf (0)
     Dtmf-relay Payload Type  : 99
     QoS ID                   : -1
     Media Source IP Addr:Port: [192.168.1.1]:19172
     Media Dest IP Addr:Port  : [192.168.1.10]:6550
5 Replies 5
alig.norbert
Level 4
Level 4
debug voip ccapi inout
debug voip rtp
.May 26 20:31:20.367 METD: voip_rtp_get_callinfo: ERROR - gccb not found
.May 26 20:31:20.367 METD: voip_rtp_exchange_context_info
.May 26 20:31:20.367 METD: voip_rtp_exchange_context_info gccb not found, context is NULL
Any ideas?
Brendan Steed
Did you ever find the answer to the issue?
Share 'show call active brief' to see the rtp counters after completing the call forward.
Opened a TAC -> no solution as the SIP provider doesn't support 100% RFC SIP.
The workaround would be that the CME terminates the CFA (e.g. B-ACD queue).
We tried the same setup with an H323 trunk to a CUCM (SIP ISP <-> CME <-> H323 <-> CUCM-CFA) and the CFA on CUCM was working.
Norbert
 Ended up we had Media Termination Point Required box ticked on Sip trunk. We unticked it and ticked the box for Early Offer support for voice and video calls (insert MTP if needed) in the Trunk Specific Configuration box of the Sip profile for the trunk.
 As per http://www.ucguerrilla.com/2014/02/dealing-with-provisional-response-and.html
 So far so good with all audio working fine.
