No contact info available for pool 1 (UCME 7.1)
shendisundari
hi,
i tried configuration cisco router 2811 (ucme 7.1) with x-lite,configuration is :
int fa0/0
     no shut-->exit
voice service voip
  allow-connections sip to sip
  sip
  registrar server expires max 1200 min 300
voice register global
  mode cme
  source-address 192.168.1.1 port 5060
  max-dn 10
  max-pool 5
  authenticate register
  tftp-path flash
  create profile
voice register dn 1
  number 51234
  allow watch
  name voip
  label 51234
voice register pool 1
  id mac DEAD.BEEF.0001 ( id mac PC1)
  number 1 dn 1
  dtmf-relay sip-notify
  username shendi password 12345
  codec g711ulaw
roouter#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
router(config)#voice register global
router(config-register-global)#create profile
router(config-register-global)#restart
after entering the command above appears notification : No contact info available for pool 1
why there notification?please explain to me,thanks
I set the ip on PC1 with ipv4:192.168.1.6 with subnet mask 255.255.255.0 and default-gateway 192.168.1.1
natiqrahimov
thank you for your help
Issa NDIAYE
Try this:
voice service voip
sip
no registrar server
no tftp-path flash
no create profile
reset
tftp-path flash:
create profile
voice service voip
sip
registrar server
reset you phone and test again
Best regards!
