Hi I need to disable Default Voicemail user greeting in Unity Connection "Sorry <name> is not available", Instead of this I need to play user extension, Please help me to do this ? Bit urgent... Regds $
Dear All, I am facing the problem where my Cisco 6941 phone doesn't know anything on screen after i did the factor reset. It is just showing Phone Not registered. "Big Concern is that i cannot press any key on phone after this". Anyone faced this...
Hi All, We integrated a GSM Gateway to the Call Manager and added this for the existing Mobile Voice Access setup. During our testing, there was an issue when calling the Mobile Voice Access feature. As per checking by the GSM Gateway personnel, he ...
Hi, I have configured and registered transcoder which is needed for transcoding g711alaw (only codec supported by ITSP) to g711ulaw (IVR). When IVR number is called ITSP sends INVITE with G.711 PCMA in in SDP part. CME replies with OK message, G.711 ...
Dear forum users. I have a client with the following:- CUCM System version: 6 Firmware:SCCP11.8-4-2Sphone model :7911Phone number : 1067The client is complaing of call drops , internal or external it doesn't matter and the time varies, can be 20 se...
I have a call manager in China . It manage two voice gateways, VGA and VGB with H323. and I configured a SIP Trunk to a SIEMENS VoIP PBX in Sweden. The SIP Trunk enable "OPTIONS ping" to monitor destination status . I created a Route Group that incl...
Hello All, How can I see who is attending Meet Me conference? Any way to see?
This is a basic question for most of you guys but I need some confirmation of call routing process. I am needing to include a couple new test DIDs into our system for a new circuit. We are receiving 3 digits from the carrier. I already have a dial-pe...
Hi, One of our client is asking if there is possibility that we can use Pin code during SRST mode.I think FAC only use for CUCM only, please correct me if I'm wrong. They used Cisco 3925 with IOS version 15.4M1. Thanks, Gritzen
HI I want use CUCM application dial rule for jabber user but there are thousands of dial rule for PSTN so i want to know that the CUCM can integration with external DB to do this ?
Good day!! One question I create two Meet-Me Numbers in my server CUCM version 11.02, Is posible set password in this conferences ?? I have only the cluster CUCM. Thanks!!
Hello all, I am trying to understand the best practice configuration for Expressway clustering. The "Cisco Expressway Cluster Creation and Maintenance" guide seems to talk about the process to cluster 2 expressway servers i.e. Creating a cluster of 2...
Is there a way to disable the Ethernet to phone port on the back of the 7965 phones? I know you can use the port to act as a switch but we are looking into disable that port completely. Can it be done?
Hello Friends I want to use GK Connect two CCM,and when i finish all config i can see this log in my GK,is there something error in this log ?i can't make a internal call now. GATEWAY TYPE PREFIX TABLE=========================Prefix: 701* Zone VLA10...
I am trying to connect PCD via sftp [ filezilla ], username - adminsftp, password - OS admin password of the PCD the connection getting timeout as attached. In firewall action - allowed, application - incomplete, session end reason - aged-out, scree...
Subject | Author | Posted |
06-05-2025 02:29 PM | ||
05-29-2025 01:49 AM | ||
05-23-2025 02:08 PM | ||
05-22-2025 11:54 PM | ||
05-21-2025 06:23 AM |
User | Count |
6 | |
3 | |
2 | |
1 | |
1 |
