No CTL Installed , File Not Found: CTLFile.Flv
KY_
Level 4
Level 4
I use Cisco 2801 with CCME, While  Cisco IPT 7965 register  a 7965, We receive a below messages,
"SEP001XXXXXXXXX.cnf.xml"
"No CTL Installed"
"File not found: CTLFile.tlv
Coul you please hel me?
Thank You,
M.Kemal Yenigün
Jonathan Schulenberg
There is no problem. CTLFile.tlv is only used when the phone is running with a secured CUCM cluster. Since the phone has the same firmware for CCME and CUCM you will see this in the log file.
Cisco 7945 how to connect asterisk pbx?
I well don't know about this. but i must configure this action.
i was read below guide.  http://row5.net/post/18655850352/cisco-ip-phone-7945-with-sip-configuration
  1. Changed SIP firmware 8.5.4.
  2. mad by this sample configuration file: http://www.dalrae.com.au/users/aalex/SEPmacaddress.cnf.xml
but my phones registering ..... registering .......
Could you help me? Please....
how did you solve this, i have the same problem. help plz thanks
