No ring back tone. Incoming call to CUCM via CUBE IVR tcl application.
alexver1978
There is no RBT in the incoming call from ISP to CUCM.
There are no 180 Ringing or 183 Session Progress in call leg (ISP - CUBE) but in call leg (CUBE-CUCM) it is present.
Could you please help me to resolve this issue?
Scheme:
ISP (83.137.x.x.) - SIP- CUBE (10.175.x.x.) (IVR) - SIP - CUCM (10.175.z.z)
CUBE config:
voice service voip
mode border-element
allow-connections sip to sip
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface Loopback1
bind media source-interface Loopback1
history-info
no call service stop
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
application
service N flash:/AA/N.tcl
paramspace english index 0
paramspace english language en
paramspace english location flash:/AA/
param max-extension-length 4
param aa-pilot 4955555555
paramspace english prefix en
param operator 5556
dial-peer voice 200 voip
preference 5
service n
destination-pattern [567]...$
session protocol sipv2
session target ipv4:10.175.z.z
incoming called-number 4955555555
voice-class codec 1
dtmf-relay cisco-rtp rtp-nte
no vad
8 Replies 8
R0g22
What is the TCL for ? The 180 being received is without a SDP. CUBE will need to generate a local ringback but the signalling is not complete.
Grab the following -
debug ccsip message
debug ccsip error
debug ccsip info
debufg voice ccapi inout
Attach CUBE config as well.
Thank you for your reply!
We use TCL script like IVR application.
Cube config and debugs ate in attchment.
Alex.
I need all the debugs enabled at once and logs collected for a single call.
ok. Debug is in attachment.
Alex
do you have any ideas?
Alex.
Alex.
I didn't realise this was updated a while ago. I will check the logs and see what's going on.
I just a INVITE and a BYE in the logs. Nothing else. Please do not take the logs using "terminal monitor". Take them in a buffer please.
