No Ringback for intermittent PSTN calls from cisco IP phones
rohit.dalvi11
CUCM release :10.5
When we make PSTN outgoing calls from the IP phone, we cannot hear the ringback at our end. The calls rings at other end and when the person receives the call he hears his own voice when he speaks. Its complete silence at our end. This issue happens for intermittent calls.
We have one publisher and 3 subscribers which are at multiple locations. This issue has been reported  only at one location.
Any assistance is appreciated.
Thanks!!
11 Replies 11
Hi.
What kind of signaling protocol are you using between VG and CUCM?
Let us know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hello Carlo,
We are using MGCP between VG and CUCM.
Just wanted to know if this can be caused due to shortage of DSP resources??
If yes, then  how do we conclude the same.
Thanks!!
Rgds,
Rohit
Hi Rohit
Please post the output of a show inventory, show diag and show controller E1 (or T1)
Carlo
Dear Carlo,
Please find attached the output for show inventory, show diag and show controller E1
Hi Rohit,
I also need your actual config and the output of a couple of a debug isdn q931 for one working and one failing call.
Carlo
Dear Carlo,
As requested,
Please find the attached Output of Good & Bad Call FYR.
Request you to Please analyze & comment on this.
During a bad call, if you double press on the help button of the phone '?', can you check if RX/TX counters are increasing.
It sounds to be that you have a routing problem between MGCP gateway and phones. Signaling path is working but media path isn't.
During faulty call, please share the output of 'sh voip rtp conn' and 'sh call active voice br'. Indicate the call number as well.
The 'show voip rtp conn' output will give the IPs of both call parties (gateway and phone). Try to ping the phone IP from the gateway using ping x.x.x.x source y.y.y.y
Hi Mohammed,
PFA the output for sh voip rtp conn' and 'sh call active voice br' during faulty call. We pinged the IP phone from the gateway and were successfully able to ping it.
Phone IP: 10.2.233.148
Gateway IP : 10.2.100.20
Can you try the following ping
ping 10.2.233.148 source 10.2.100.20
Can you post the debug mgcp packets output for the calls?
