No Ringback Heard on Internal Calls
Not applicable
Hello Everyone,
I have an issue in regards to some 6921 Ip Phones registered to a CUCM.
The problem is that when i make a call to another Phone registered to the same CUCM, i hear no Ringback, but the other phone does ring, and even when the call is connected I can send and receive audio without any issues.
This problem is only present when calling another IP Phone, when i call a number on the PSTN (say a cell phone) i can hear the ringback as normal.
Can anyone help me with this issue??? Any help would really be appreciated.
My CUCM version is 8.5.1
Thanks in Advance!!
Edson
Tapan Dutt
What is the Firmware on the Phone?
Tapan
Hello Edson, I had the same issue with the 6921 with firmware 9-1-1 and 9-2-1 in CME. You should install the last firmware for the 6921 (I think is 9-3-3-2 or similar) and it could fix it. Also I didnt hear the busy tone, and with this firmware works fine.
Rodrigo
