No Ringback Tone on VoIP Inbound Calls to Cisco CallManager when using TCL script auto attendant
Nguyen KeThuc
Hi all,
I have one Cisco Voice gateway with one E1 connection. I am using a TCL script auto attendant. However, incoming calls don't get any ring back tone util IP Phones answer. Any ideas for me?
Thuc
Murali_DS
I'm not well versed in TCL, It seems the prob in the SIP sessions. Can u enable PRACK on the Dial peer and the SIP profile associated SIP trunk and chk. U can enable by folowing the below steps.
CUBE
dial-peer level:
                              dial-peer voice XXXX voip
              voice-class sip rel1xx require 100rel
CUCM
               Device -> Device settings -> Sip profile -> Trunk Specific Configuration
                              SIP Rel1XX Options Required Field : Send Prack if 1xx contains SDP
Thx
M
Thank you for reply.
I test my system again and see that there is just  not busy tone if the destination is talking .
I found  that I missed en_reenter_dest.au file in the flash. When my destination is busy, procedure act_Select will be triggered. So, the TCL script plays this file. Now, it is fine.
Thuc
