No RX alerting before RX connect
jayage
Hi guys,
we got a strange issue at one of our italian locations. Only when one person calls a french mobile number, the person does not get a ringback tone, the voicemail of the cell phone instantly answers. If any other person of this site calls the given french mobile number they hear it ring before the voicemail or even the owner answers. Ringback tone generally works. Below is a part of the isdn q931 debug output (I changed the numbers to avoid rogue calls). When I change the callers number by using another External phone number mask I can see the RX alerting coming in > normal behavior.
I was wondering if the owner of the cell phone blocked the person or maybe something similar...
Any idea on this is greatly appreatiated!
Thanks and best regards
Jochen
    Calling Party Number i = 0x0081, '0341123456'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '00331234567'
Dec 11 10:30:19.101: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8E0A
        Channel ID i = 0xA98384
                Exclusive, Channel 4
Dec 11 10:30:20.973: ISDN Se0/1/0:15 Q931: RX <- PROGRESS pd = 8  callref = 0x8E0A
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Dec 11 10:30:21.421: ISDN Se0/1/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8E0A
        Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
        Connected Number i = 0x00C3
This is a problem at remote side. They automatically connect for some
reason. I don't think you can do anything from your side
can we get both working and non-working log ?
Balram
Ex-Cisco TAC
Please rate if you find this helpful
Thank You
Balram
Yes of cource, here it is. As you can see we receive alerting before the call got connected. We only changed the calling by increasing it by one. Real extension is 423, changed by external phone number mask to 424. Then it works in normal manner.
Mon Dec 11 11:45:33 2017: <191>537387: Dec 11 10:45:33.516: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0E0F
Mon Dec 11 11:45:33 2017: <191>537388:     Sending Complete
Mon Dec 11 11:45:33 2017: <191>537389:     Bearer Capability i = 0x8090A3
Mon Dec 11 11:45:33 2017: <191>537390:         Standard = CCITT
Mon Dec 11 11:45:33 2017: <191>537391:         Transfer Capability = Speech
Mon Dec 11 11:45:33 2017: <191>537392:         Transfer Mode = Circuit
Mon Dec 11 11:45:33 2017: <191>537393:         Transfer Rate = 64 kbit/s
Mon Dec 11 11:45:33 2017: <191>537394:     Channel ID i = 0xA98381
Mon Dec 11 11:45:33 2017: <191>537395:         Exclusive, Channel 1
Mon Dec 11 11:45:33 2017: <191>537396:     Progress Ind i = 0x8183 - Origination address is non-ISDN
Mon Dec 11 11:45:33 2017: <191>537397:     Calling Party Number i = 0x0081, '0341123457'
Mon Dec 11 11:45:33 2017: <191>537398:         Plan:Unknown, Type:Unknown
Mon Dec 11 11:45:33 2017: <191>537399:     Called Party Number i = 0x80, '00331234567'
Mon Dec 11 11:45:33 2017: <191>537400:         Plan:Unknown, Type:Unknown
Mon Dec 11 11:45:34 2017: <191>537401: Dec 11 10:45:33.589: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8E0F
Mon Dec 11 11:45:34 2017: <191>537402:     Channel ID i = 0xA98381
Mon Dec 11 11:45:34 2017: <191>537403:         Exclusive, Channel 1
Mon Dec 11 11:45:34 2017: <191>537404: Dec 11 10:45:34.064: //-1/47B7F4800004/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x7F0A797AEC68; count=1
Mon Dec 11 11:45:34 2017: <191>537405: Dec 11 10:45:34.064: //-1/47B7F4800004/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x7F0A787190A8
Mon Dec 11 11:45:34 2017: <191>537406: Dec 11 10:45:34.103: ISDN Se0/1/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x0E0D
Mon Dec 11 11:45:34 2017: <191>537407: Dec 11 10:45:34.105: //-1/47B7F4800004/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x0
Mon Dec 11 11:45:34 2017: <191>537408: Dec 11 10:45:34.142: ISDN Se0/1/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8E0D
Mon Dec 11 11:45:36 2017: <191>537409: Dec 11 10:45:35.817: ISDN Se0/1/0:15 Q931: RX <- PROGRESS pd = 8  callref = 0x8E0F
Mon Dec 11 11:45:36 2017: <191>537410:     Progress Ind i = 0x8288 - In-band info or appropriate now available
Mon Dec 11 11:45:39 2017: <191>537411: Dec 11 10:45:38.109: ISDN Se0/1/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8E0F
Mon Dec 11 11:45:39 2017: <191>537412:     Progress Ind i = 0x8288 - In-band info or appropriate now available
Mon Dec 11 11:45:39 2017: <191>537413: Dec 11 10:45:38.517: ISDN Se0/1/0:15 Q931: RX <- PROGRESS pd = 8  callref = 0x8E0F
Mon Dec 11 11:45:39 2017: <191>537414:     Progress Ind i = 0x8288 - In-band info or appropriate now available
Mon Dec 11 11:45:40 2017: <191>537415: Dec 11 10:45:40.812: ISDN Se0/1/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8E0F
can you please copy working and non-working q931 debugs to text and attached ?
also mention calling and called number with changed number.
Thank You
Balram
