Hi, While attempting to download a phone's configuration via http the following error occurs. XML Parsing Error: prefix not bound to a namespace Can someone tell me how to go about resolving this error and downloading the configuration file i ...
I am loooking for the maximum number of letters/characters appears on the phine displayIf we exceed characters in length, then phone will not display those exceeded characters of the display name (Line text Lable)I would like to know the maximum leng...
Hi All, I have been chasing some strange issues regarding audio streams routing to endpoints they shouldn't, Ultimately because they needed MTP resources that weren't available locally. The primary issue turned out to be DTMF mismatch because som...
Does anyone know if this is possible? I don't see any options.
Hi Guys, I am trying generate the report about issues with the IP Phone 8851, but, when to press the button send Problem description I receive the message: "Failed to upload data, but the report can be accessed form the phone directly". Thanks, ...
Hi all,any chance somebody can clarify to me why do we really need USB eTokens? Let's say I want to configure encrypted signaling (and maybe media) between my IP phones inside local network. I know from Microsoft world that you can create all this wi...
Hi, my network drawing is attached. i have SIP and SCCP phones in my network, i am using MGCP gateway. i am able to direct my SCCP users to outbound calls / interfaces by using route patterns. however i am unable to do so for my SIP phones. SIP Phone...
Dear all, I am currently setting up a CUBE (ISR 4321) in order to connect to the ISP's SIP Trunk. I can establish connections to the outside world, but seemingly can't get it to work routing calls to the internal phones. I'd be happy about any advi...
Hello, I have 2 MGCP gateways connected to CUCM cluster. Each gateway has 4 PRIs from 2 different service providers. Our Primary PRI (number starting with 3918XXXX)is failing very frequently. Most of the users in the office have announced DID numbe...
Hi, I want to configure a Basic Cisco Paging Server. I use the included OVA on Cisco CUCMBE6K. The Live Audio Page to 50 phones in Basic implementation is used. I configured CUCM and the singlewire informcast server.I've got connection betwenn the...
Good day everyone, I want to verify how to craft a redundant BE6K appliance given these ff. specifications(see attached file). 1.Do I need more information from the client or this will suffice? 2.Do I need additional license for it to become a red...
We are transitioning over to SIP. We have run into an issue calling one of our customers MetLife 980-949-5529. When we try to place calls to them we are getting error 422 - session interval too small. MetLife has their min-se timer setting set to 600...
Hi, I just received my new 8861 3PCC IP phone and I'm using a 3rd party supplier. I have searched everywhere how to put in the SIP information to the phone but can't find it. Can anyone help me regarding this?
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabela normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-pa...
| Subject | Author | Posted |
| 03-04-2026 06:20 AM | ||
| 03-02-2026 07:40 AM | ||
| 03-02-2026 07:34 AM | ||
| 01-16-2026 03:24 AM | ||
| 12-31-2025 01:52 PM |
