05-01-2015 11:17 AM - edited 03-17-2019 02:52 AM
I have situation if anyone faced this issue before which when I dial internal extension during Auto-Attend, it is ringing to internal extension phone but when answer no sound can hear in both end, but when i dialed 0 during Auto-Attend for operator phone or call directly DID it is working fine.
Thank you
05-01-2015 06:02 PM
When you say Auto-Attend are you referring to a Call-Handler?
Call manager version?
Unity version? or Unity Connection version?
Thanks.
05-01-2015 06:42 PM
Yes, call-handler, and Call Manager/Unity connection Version: 10.5
Thank you
05-01-2015 07:45 PM
Any difference if you call call handler from an internal phone versus calling the call handler from an outside phone line?
Take a look at the posting below. Sounds like exact same symptoms.
https://supportforums.cisco.com/discussion/11975636/no-audio-both-ends-when-you-enter-extension-during-greetings-call-handler
"The only way I was able to get this solved was checked the MTP on trunk in the CUCM. I have never seen this before with no two-way audio between CUC and CUCM."
Hope this helps,
Please rate helpful answers,
Thanks.
05-01-2015 11:58 PM
From internal works fine, only from outside
Thank you
05-02-2015 12:54 AM
Is MTP required checked on the trunks?
SIP trunks?
05-02-2015 03:58 AM
I tried both check/Uncheck sip trunk CUCM to CUC MTP, but same thing, after 15 sec, it is disconnect by default without hear sound
Thank you
05-02-2015 06:14 AM
Sounds like a codec mismatch.
Trying to understand your setup a little better.
SIP trunk from the phone company to the Call manager?
SIP trunk integration between Call manager and Unity Connection?
05-02-2015 06:33 AM
Yes,
-IP Phone---CUCM---SIP---CUBE----SIP---ITSP
-CUCM---SIP---CUC
Thank you
T
05-02-2015 06:53 AM
Do a "debug ccsip mess" on your gateway.
Make a test call and upload the debug.
I'm no SIP expert by no means, but if we don't see the problem, maybe a SIP guru will chime in and help us out.
Another question, do you have a MTP configured?
05-02-2015 06:43 PM
05-03-2015 11:35 AM
Please do a debug ccsip all
and upload the debug. If I'm looking at the debug correctly, i see the codecs that are supported, but not what is negotiated.
On a successful internal call, what is the negotiated codec when a call is transferred from a call handler to an internal DN.
05-04-2015 06:53 AM
Hi Charles
Issue has been resolved, just add Payload 97, and works (:
Thank you
05-04-2015 06:54 AM
Very good!
Thanks for the update.
05-06-2015 01:33 PM
Hi All,
How to Configure Auto Attendance on C2911-CME-SRST/K9 ?
we have this :-
1- C2911-CME-SRST/K9 2911 Voice Bundle w/PVDM3-16,FL-CME-SRST-25, UC License PAK
2- VIC2-4FXO
3- CP-7945G= QTY1
4- CP-7942G= QTY3
5- CP-7931G QTY1
we did all the basic configuration , we can call each other extensions and we can call out lines
and also we can receive incoming calls direct to operator on extension 400 .
now we want to add Auto Attendance , any one can help us ?
kindly see the attached configuration and also the flash files
