12-17-2007 10:14 PM - edited 03-15-2019 07:50 AM
Someone told me that there is a new phone that will do both 802.11b with UC and cell. Does this phone exist?
12-18-2007 01:08 AM
Hi Steve,
Yes there is the Nokia E Series (E61/E61i/E65) that are both 802.11 WiFi GSM/3G.
There is also the Nokia Intellisync Call Connect client application available for these Symbian OS Devices, that will let you run the phone as a "skinny" client to certain versions of Callmanager and Callmanager Express.
They can also run as native SIP endpoints over WiFi, but this functionality is very dependent on the Operator Firmware version.
Bill.
12-18-2007 08:13 PM
Bill do you know where I can buy one of these to test?
12-19-2007 03:46 AM
Where can I find how to configure Nokia Phones on CallManager 4.x ?
Thanks.
Andrei.
12-19-2007 04:55 AM
Hi, andrei,
Callmanager 4.x has no support for sip endpoints. So you need the sccp client from nokia:
Hope this helps.
Steffen
