I am attempting to get Nortel Phones MWI to work with Unity Connection in the configuration below.
Unity Connection 8.6 <---SIP or SCCP---> Call Manager 8.6 <---SIP ---> Avaya Session Manager 6.1 <---SIP---> Nortel CS100E 7.5 <---Unistem---> Nortel Phone
Here is the link with the Normalization script for MWI on Nortel
http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns728/ns784/989942.html
Here is the Avaya document that I referenced for SIP integration to Avaya Session Manager.
https://devconnect.avaya.com/public/download/interop/SM61CS1K75CUCM8.pdf
Messages-Waiting: yes
|1,100,63,1.11268^10.252.192.79^*
09:58:35.728 |//SIP/SIPUdp/wait_SdlSPISignal: Outgoing SIP UDP message to 10.253.198.181:[5060]:
[23695,NET]
NOTIFY sip:5560297@10.253.198.181:5060 SIP/2.0
Via: SIP/2.0/UDP 10.253.198.31:5060;branch=z9hG4bKa923da325e8
From: <sip:voicemail@10.253.198.31>;tag=591882809 <--------
To: <sip:5560297@10.253.198.181>
Call-ID: fee6a500-461171b-95c-1fc6fd0a@10.253.198.31
CSeq: 101 NOTIFY
Max-Forwards: 70
Date: Tue, 04 Sep 2012 14:58:35 GMT
User-Agent: Cisco-CUCM8.6
Event: message-summary
Subscription-State: active
Contact: <sip:voicemail@10.253.198.31:5060>
Content-Type: application/simple-message-summary
Content-Length: 23
My biggest concern is there is a blurb in the MWI Nortel document that states:
-- Modify the From header so that the userpart is numeric. CUCM will natively send
-- 'voicemail' as the userpart. Nortel does not handle that. This code changes
-- the user part to 1000 or the value of the configured script parameter: mwi-number.
In the Call Manager traces I never see it modify voicemail@10.253.198.31 like you see above to 1000@10.253.198.31. So something tells me I do not have syntax correctly or something.
On the Nortel Console I get:
ERR4080 FAIL Q+P 60297 0
Basic call routing is working. My extension length is 5 digits long but prepend/strip a "55" as a steering code to/from Session Manager.
I will attach the rest of the Call Manager trace and my Nortel MWI copy/paste script.
Any ideas are much appreciated.
Not sure but there must be some sort of syntax error or programming logic mistake in the example but this is what worked for me today. It is obviously a much shorter script than what is posted so if I find any issues during testing in the next couple of days I may take another look about adding the rest in there piece by piece.
Nortel = {}
Nortel.allowHeaders = {"History-Info"}
local mwi_number = scriptParameters.getValue("mwi-number")
if not mwi_number
then
mwi_number = "1000"
end
function Nortel.outbound_ANY(msg)
msg:removeHeaderValue("Allow", "OPTIONS")
end
function Nortel.outbound_ANY_ANY(msg)
end
function Nortel.outbound_NOTIFY(msg)
local from = msg:getHeader("From")
if from
then
from = from:gsub("voicemail", mwi_number)
msg:modifyHeader("From", from)
msg:addHeaderUriParameter("From", "user", "phone")
end
end
return Nortel
