05-19-2016 03:16 AM - edited 03-17-2019 06:58 AM
Hi All,
I came across an issue where users are not able to dial 800 toll free numbers.
They are using CME and sip trunk to provider. when they are dialling 0800XXXXXXX getting busy signal not connecting.
for test, we tried calling 8001248888 from extension 5370.
logs attached.
in the config i saw that toll free dial peer is missing so i added below config.
voice translation-rule 800
rule 1 /^0/ //
voice translation-profile 800
translate called 800
dial-peer voice 800 voip
corlist outgoing INTERNATIONAL
description **Outgoing Call to 800**
translation-profile outgoing 800
destination-pattern .
session protocol sipv2
session target sip-server
session transport udp
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
codec g711ulaw
no vad
still calls not working,
regards
Vijay
05-19-2016 05:05 AM
You are sending only 0 to SIP provider. I didn't check full config to get the reason. Configure more specific destination pattern like 0800.......$ or 800.......$ depends on what you are going to dial and see if it works for you.
- Vivek
05-19-2016 07:48 AM
Thanks Vivek,
I follow as per your suggestion, i guess service provider is not allowing the 800 calls. as per log below.
I checked the configuration for CME, there was missing dial peer for dialling toll free 800 numbers, after adding the dial peer, I made test calls by dialling 8001248888 toll free number but we are getting busy signal. From the logs I see that SIP service provider is sending no routes found for these numbers. Can we ask the service provide to check on this issue and adjust their end configuration for 800 numbers.
Below is the dial peer i currently added in CME
destination-pattern 800.......$
dtmf-relay rtp-nte
codec g711ulaw
no vad
now below is the log in which we are getting 480 not found error. I tried sending 08001248888 and 8001248888 to service provider but in both case we are getting 480 error from service provider.
INVITE sip:8001248888@94.77.211.70:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.6.2:5060;branch=z9hG4bK945B16EA
To: <sip:8001248888@94.77.211.70>
Date: Thu, 19 May 2016 13:17:21 GMT
Call-ID: DA56DB54-1CFA11E6-9679F7C4-48FC87FB@192.168.6.2
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 3632085194-0486150630-2524248004-1224509435
User-Agent: Cisco-SIPGateway/IOS-15.3.3.M2
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1463663841
Contact: <sip:5280@192.168.6.2:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 293
v=0
o=CiscoSystemsSIP-GW-UserAgent 1865 1986 IN IP4 192.168.6.2
s=SIP Call
c=IN IP4 192.168.6.2
t=0 0
m=audio 18008 RTP/AVP 0 100 101
a=rtpmap:0 PCMU/8000
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Received:
SIP/2.0 480 No Routes Found Service Provider is sending this error
To: <sip:8001248888@94.77.211.70>;tag=aprqngfrt-u61ast30000a6
CSeq: 101 INVITE
ACK sip:8001248888@94.77.211.70:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
05-19-2016 11:27 PM
Hi Vijay,
Now we can seen number being sent correctly in Request-URI but still service provider is returning 480 error response. You can cross verify if the number in Request-URI is correct, else should report it to service provider.
- Vivek
05-22-2016 12:32 AM
Hi Vijay,
In initial INVITE, you are sending only 4 digits in calling party number. Does your provider allow it?
Best Regards,
Sudheer Shenoy
