Do the DNA on CUCM and see if the calls are getting routed or not. If they are, collect the debugs from Gateway and check where the call is getting disconnected.
Abhay
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Havenāt Found It Yet, Keep Looking. Donāt Settle
