88xx phone always use line 2
wsteahr01
I am familiar with the "Always use prime line" setting on these phones. Is there a way to change "prime line" to line 2? Or another way to have outbound calls prefer line 2 instead? Thank you.
This is an expected behavior of SIP Phones, if you do not configure line 1 then it wont get registered as config file info for Line will be empty.
Find the below forum helpful
https://supportforums.cisco.com/discussion/12213011/8961-wont-register
Abhay
Kindly rate all helpful posts !!!
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
Hope this below link helps
https://supportforums.cisco.com/discussion/13218711/88xx-enhanced-line-mode-always-use-prime-line-features
Abhay
Abhay Singh Reyal
Thank you Abhay. That's sort of what I was looking for.
Do you know if there's any way to register a phone with line 1 unconfigured and line 2 configured? On 8800 phones they are unprovisioned until line 1 is configured.
Abhay
Abhay Singh Reyal
