Not able to update config via GUI
kevinshkong11
Hi ALL,
I am not able to update/add/delete any configuration via GUI.
After I save change, the page will hung and need to refresh.
IOS: Version 15.2(4)M1
CME: Version 9.1
Need you expertise.
Thank you.
Jaime Valencia
Why don't you simply update via CLI??
java
if this helps, please rate
Hi Jaime,
The customer is not familiar with CLI.
Thank you.
charchan
I see this very likely a browser compatibility issue.  Check your CME version using GUI by moving pointer to “Help > About” then click mouse button.  If CME GUI complains about requiring Internet Explorer 5.5+, then it probably is the browser compatibility problem.
I have had success editing phone configurations using CME GUI (IOS version 15.2(4)M5 / CME 9.1) using Internet Explorer 10.0, but the editing process is EXTREMELY tedious and painful, which I will save the story for another thread.
Amit Sharawat
Hi Kevin,
Could you please collect the following logs for a test scenario:
debug ip http client
~Amit
