03-14-2022 08:36 AM
I'm trying to make changes on the sidecar programming on a 7975 phone.
When I select the drop down to assign a directory number to it, not all of the numbers in my directory are listed. It seems like it lists numbers starting at 1000 and ends in the early 5000's (5009).
I have 5000 numbers after 5009 as well as 6000, 7000, 8000 and 9000 numbers (obviously not a thousand numbers in each range).
It seems like the drop down is limited to a certain amount of numbers to be displayed without any option to expand the list.
Is this possible?
CUCM System version: 12.0.1.21900-7
Thanks - Eric
Solved! Go to Solution.
03-14-2022 09:09 AM
If you know the extension you can type it instead of searching the drop down menu
03-14-2022 09:09 AM
03-14-2022 09:19 AM
Thanks Nithin,
Sometimes you don't see the obvious until it slaps you in the face.
I also noticed the "Find" button there also.
Humbly going back to reprogramming the phone.
Thanks for your help.
- Eric
