NTP Issue Subscribe Vmware
alfredobosca
I am struggling with the NTP issue that doesn't permit to create the cluster of CUCM in Vmware.
I have verified:
1) NTP running OK on the server
2) Server subscriber was added in System > Server from publisher
3)ntp_stratum -->warning status // Currently has the value "1" Would be possible to change this value?
Best regards,
Rajan
NTP stratum of 1 should be fine. You need to check whether network connectivity is fine between these 2 servers (Pub & SUb) and firewalls if any between the Publisher and this sub allowing connection for NTP synch.
Rajan
