Null is displayed with ccmuser page
y-hirasawa
When I change ON/OFF of the check box of DND of Device Setting of the ccmuser page and do Save, null is displayed.
The setting of ON/OFF is reflected. Is there any method so that null is not displayed?
In this case, CUCM 7.1 (3) is used.
Even if IE8 is used or FX3.6 is used, it is a same result.
Thank you.
This problem can be solved.
BR
Yasuyuki
