Number cut off on CME
MarcoM
Hi all,
when receive a fax from a number of a customer my cme cut same digits.
For example when receive fax from 271090935 to 331755511, the CME cut two final digits 11 and route a call to internal 01.
This strange event occurs only on some numbers not all incoming fax.
I attached debug of a trace.
Below are some parts of the configuration:
dial-peer voice 101 pots
translation-profile outgoing OUTGOING
destination-pattern 0T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 0/0/0:15
voice-port 0/0/0:15
input gain -2
echo-cancel coverage 32
cptone IT
bearer-cap Speech
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn overlap-receiving T302 1000
isdn incoming-voice voice
isdn send-alerting
isdn negotiate-bchan
no cdp enable
voice translation-rule 101
rule 2 /^\(...\)$/ /03317555\1/
voice translation-profile OUTGOING
translate calling 101
num-exp 331755501.. ..
num-exp 331755501... ...
num-exp 3317555.. ..
num-exp 3317555 01
Anyone help me please?
Thanks in advance.
M
30 Replies 30
Hi Marco.
Glad that I helped you
Ciao
Carlo
Please rate all helpful posts "The more you help the more you learn"
