Number xx is not a valid voice register dn. Re-enter 'list.'
Cloudy
i try to do config call blast hunt-group parallel but cannot to inject command list .  anyone help me
it reture as "Number xx is not a valid voice register dn. Re-enter 'list.'"
i have require all ip phone ring form PSTN Incomming call. my ip phone is cisco 7942 and using with cisco 1861
2 Accepted Solutions
I am not sure how you want to configure it but here is a sample
Router(config)# *voice hunt-group 4 parallel*
Router(config-voice-hunt-group)# *pilot 1000*
Router(config-voice-hunt-group)# *list 1001, 1002, 1003, 1004*
Router(config-voice-hunt-group)# *final 2000*
Router(config-voice-hunt-group)# *timeout 20*
Router(config-voice-hunt-group)# *exit*
*Or you can use ephone hunt.*
*Also verify if your IOS version has the command. *
1) What is the Version of you CUCME.
CHeck by command show telephony-service.
2) If it is before 4.3  the EPhone-dn is not supported for the Voice hunt group. You need to upgrade the IOS to Upgrade the CUCME Version.
Ephone-Hunt Groups and Voice Hunt-Groups Comparison
SIP phones support Voice Hunt-Groups. SCCP phones support Ephone-Hunt Groups, and in Cisco Unified CME 4.3 and later versions, SCCP phones also support Voice Hunt-Groups. Table 1compares the features of Ephone-Hunt Groups and Voice Hunt-Groups.
Table 3. Feature Comparison of Ephone-Hunt Groups and Voice Hunt-Groups
Feature
Ephone Hunt
Voice Hunt Group
Endpoints Supported
SCCP only
SIP, SCCP, PSTN, and FXS
Parallel Hunt Groups (Call Blast)
No (for alternative, see Shared- Line Overlays
Yes
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm/cmecover.html#concept_074B26EAA8B94547AB55ACAF2F862E44
*****DON'T forget to rate or accept solution as applicable.
6 Replies 6
I try to config but return as below
VOICE_GW(config-voice-hunt-group)#list 6510 , 6511 ,6512
Number 6510 is not a valid voice register dn. Re-enter 'list.'
Feature
Ephone Hunt
Voice Hunt Group
Endpoints Supported
SCCP only
Yes
The Problem is IOS version. after upgrate to 15.xx it working now
G8, please remember to rate useful posts
Did you configure voice register dns for the numbers before putting them in
the list
