05-31-2007 07:46 AM - edited 03-14-2019 09:49 PM
I am getting one way audio on a single phone out of 75 phones at one site. It only occurs on calls coming or going to the outside. Internal calls have no problem. I've swapped the phones, changed the network cables, changed the switchport, checked the CSS and Device pool. All settings are the same as the other 75 phones that have no problems. It only appears to be this extension.
05-31-2007 09:00 AM
Try to remove the data VLAN from the port where the phone is connected on the switch and leave the port with the voice VLAN only. Let me know if it resolves the issue. Also, make sure that the switch port and the phone itself are set to full duplex or auto.
05-31-2007 10:23 AM
If you changed everything, even the switch port and other phones are working on that switch, please check the internal building patching to that place (user). Its the only remaining option :)...
Just try!
LT
05-31-2007 11:14 AM
Found the problem. A co-worker had changed the DHCP server and had the wrong gateway in the scope options. This phone was the first to renew its IP address with the new server and the gateway was not populated on the phone itself. Once I fixed the gateway on the DHCP scope options and reset the phone all is good. Thanks for the ideas. It was a tricky one.
