One way audio on VG224
Tommer Catlin
What would cause VG224 one way audio? We all know most audio problems are network related, but could there a problem with the send/receive punchdowns on the VG devices? Anyone ever had that problem?
cheers!
davidraasch
check if ip Routing is configured. This was the cause for one way audio at my site.
David
No ip routing is in the configs. Im wondering if it's at the switchport. Anything with punchdown of the R-21 cable? Its standard pinout to RJ45 patch panel right?
Ok, so another test. I have (2) analog phones.
MGCP controlled
Port 0 analog phone extension 5000
Port 1 analog phone extension 5001
5000 calls 5001. Call connects, no audio, one way audio. Either participant can not hear each other.
Punchdown problem??
