IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6169 Views
  • 14 replies
Hey all, So I've got a pretty simple setup, all my phones are in the same Device Pool, with the same Date/Time Group (set to central time zone, etc.) I applied all the recommended DST patches LAST march and again in October.However when DST rolled a...
thanmad by Level 1
  • 412 Views
  • 6 replies
Guys, I'd like to implement a QoS/CoS for my Voice traffic. I have a 4Gb MetroE connection for my data VLAN and 2Gb MetroE connection for my voice VLAN. I'm using a C3750 and using static routing. When my 4Gb is down, I'd like the 2Gb to share the 50...
mhelvin by Level 1
  • 608 Views
  • 1 replies
I have to install a CCME in a hotel and my problem is how to do the billing per room and then charge it to the final invoice in the check out.Is there any billing solution for integrating it in CCME? Which solution do you recommend?Regards
I am having difficulty configuring an ATA with above reception phone. It will lock the ATA up and hence the line. The supplier has reccomended configuring secondary dialtone as Ghana or 400hz. I assume this will be "dialtone 2" is this possible/ho...
