One way audio through isdn line
nybble2012
Hello all,
I have a 2801 router with C2801-advipservicesk9-mz.124-24.T5, CME 7.1 installed and an isdn vic2-2bri-nt/te card.
I'm trying to make phone calls with the ephones through and from the isdn line but in both cases i experience one way audio,the other party can hear me but i can't hear them.
The ephones communicate with each other with no problems..
I have tried to change between many codecs but the problem still persists.
The problem is only between isdn calls..
Any ideas what's going wrong?
Thanks.
Antony.
8 Replies 8
paolo bevilacqua
Update IOS and check again.
Hello again,
i updated to 151-4.m4 with CME 8.6  and still the same problem..I also replace the VIC2-2BRI-NT/TE card with a new one but nothing change..
Here is the debug isdn q931 output:
*Sep 12 09:49:54.195: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x
0 0x0, Calling num 1002
*Sep 12 09:49:54.199: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x
0 0x0, Called num 21095XXXXX
*Sep 12 09:49:54.211: ISDN BR0/1/0 Q931: Sending SETUP  callref = 0x0008 callID
= 0x800A switch = basic-net3 interface = User
*Sep 12 09:49:54.211: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8  callref = 0x08
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x81
                Preferred, B1
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x0080, '1002'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '21095XXXXX'
*Sep 12 09:49:54.495: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8  callref = 0x88
        Channel ID i = 0x89
                Exclusive, B1
*Sep 12 09:49:55.063: ISDN BR0/1/0 Q931: RX <- ALERTING pd = 8  callref = 0x88
        Progress Ind i = 0x8488 - In-band info or appropriate now available
*Sep 12 09:50:04.211: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8  callref = 0x08
        Cause i = 0x8090 - Normal call clearing
*Sep 12 09:50:04.323: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8  callref = 0x88
*Sep 12 09:50:04.323: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x
08
Any ideas?
Thanks again..
Antony
Ask telco to come on premises and verify that they can talk using their test equipment.
If that works you may have a faulty DSP module in router.
As per your debug, I see that your call isn't completed (normal clearing). Not sure whether you disconnected the call before connected state or something else.
We need the debugs for full call till connected stage. Once the call is connected, post the output of "show call active voice calling-number ..." and lets see RX/TX. Also, lets see controller stats.
Also, from your debugs I can see that the calling number sent to teleco is "1002" which I doubt it will be accepted. Therefore, your call will be dropped by teleco rather than completed.
You need to implement a voice translation rule or use dial-plan command to manipulate the calling number correctly.
"Please rate useful posts"
From your debugs I can see that the calling number sent to teleco is "1002" which won't be definitly accepted. Therefore, your call will be dropped by teleco rather than completed.
Do not assume that telco will not accept a calling number like that. They will simply replace it with the assigned number.
Thanks Paolo for highligting this. In fact I have seen only telecos who drop those calls. Good to know that some are replacing the calling number.
Thanks for sharing the info
It was my mistake the above debug because when i make a call i don't even hear the ring tone so i don't know if the other party answer the call.
The correct is this one:
Sep 12 10:24:55.047: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x
*Sep 12 10:24:55.047: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x
*Sep 12 10:24:55.063: ISDN BR0/1/0 Q931: Sending SETUP  callref = 0x0009 callID
= 0x800B switch = basic-net3 interface = User
*Sep 12 10:24:55.063: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8  callref = 0x09
                Standard = CCITT
        Channel ID i = 0x81
                Preferred, B1
*Sep 12 10:24:55.259: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8  callref = 0x89
        Channel ID i = 0x89
                Exclusive, B1
*Sep 12 10:24:55.635: ISDN BR0/1/0 Q931: RX <- ALERTING pd = 8  callref = 0x89
*Sep 12 10:24:58.923: ISDN BR0/1/0 Q931: RX <- CONNECT pd = 8  callref = 0x89
        Date/Time i = 0x0C090C0D08
                Date (dd-mm-yr)   = 12-09-12
                Time (hr:mnt:sec) = 13:08:76
        Connected Number i = 0x0183, '21095XXXXX'
*Sep 12 10:24:58.927: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to
1002 N/A
*Sep 12 10:24:58.927: ISDN BR0/1/0 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0
9
*Sep 12 10:25:01.451: %ISDN-6-DISCONNECT: Interface BRI0/1/0:1  disconnected fro
m 21095XXXXX , call lasted 2 seconds
*Sep 12 10:25:01.451: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8  callref = 0x09
*Sep 12 10:25:01.619: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8  callref = 0x89
*Sep 12 10:25:01.623: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x
09
Cisctest#
Cisctest#
*Sep 12 10:25:16.607: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L
Here is the active voice calling-number output and the controller stats
Cisctest#show call active voice calling-number 1002
Telephony call-legs: 2
SIP call-legs: 0
H323 call-legs: 0
Call agent controlled call-legs: 0
SCCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 2
GENERIC:
SetupTime=*12:58:21.411 Athens Wed Sep 12 2012
Index=1
PeerAddress=1002
PeerSubAddress=
PeerId=20002
PeerIfIndex=16
LogicalIfIndex=15
ConnectTime=*12:58:26.071 Athens Wed Sep 12 2012
CallDuration=00:00:37 sec
CallState=4
CallOrigin=2
ChargedUnits=0
InfoType=speech
TransmitPackets=1707
TransmitBytes=54624
ReceivePackets=0
ReceiveBytes=0
TELE:
ConnectionId=[0x99D560CD 0xFBFF11E1 0x8056EF10 0x82459141]
IncomingConnectionId=[0x99D560CD 0xFBFF11E1 0x8056EF10 0x82459141]
CallID=31
GlobalCallId=[0x99D560CD 0xFBFF11E1 0x8056EF10 0x82459141]
Port=50/0/2 (31)
BearerChannel=50/0/2.0
TxDuration=34140 ms
VoiceTxDuration=34140 ms
FaxTxDuration=0 ms
CoderTypeRate=g729r8
NoiseLevel=0
ACOMLevel=0
OutSignalLevel=0
InSignalLevel=0
InfoActivity=2
ERLLevel=0
EchoCancellerMaxReflector=29556
SessionTarget=
ImgPages=0
CallerName=
CallerIDBlocked=False
LongDurationCallDetected=no
LongDurCallTimeStamp=
LongDurCallDuration=
OriginalCallingNumber=1002
OriginalCallingOctet=0x0
OriginalCalledNumber=
OriginalCalledOctet=0x80
OriginalRedirectCalledNumber=
OriginalRedirectCalledOctet=0x0
TranslatedCallingNumber=1002
TranslatedCallingOctet=0x0
TranslatedCalledNumber=
TranslatedCalledOctet=0x80
TranslatedRedirectCalledNumber=
TranslatedRedirectCalledOctet=0x0
GwCollectedCalledNumber=921095XXXXXX
GwReceivedCallingNumber=1002
GwReceivedCallingOctet3=0x0
GwReceivedCallingOctet3a=0x0
MlppServiceDomainNW=0 (none)
MlppServiceDomainID=0
PrecedenceLevel=-1 (PRECEDENCE_LEVEL_NONE)
GENERIC:
SetupTime=*12:58:24.049 Athens Wed Sep 12 2012
Index=1
PeerAddress=921095XXXXX
PeerSubAddress=
PeerId=1
PeerIfIndex=11
LogicalIfIndex=0
ConnectTime=*12:58:26.069 Athens Wed Sep 12 2012
CallState=4
CallOrigin=1
ChargedUnits=0
InfoType=speech
TransmitPackets=1953
TransmitBytes=54684
ReceivePackets=1957
ReceiveBytes=39140
TELE:
CallID=32
Port=0/1/0 (32)
BearerChannel=0/1/0.1
TxDuration=39140 ms
VoiceTxDuration=39140 ms
FaxTxDuration=0 ms
NoiseLevel=-69
ACOMLevel=45
OutSignalLevel=-60
InSignalLevel=-64
InfoActivity=1
ERLLevel=45
EchoCancellerMaxReflector=4
SessionTarget=
ImgPages=0
CallerName=
AlertTimepoint=*12:58:24.449 Athens Wed Sep 12 2012
TranslatedCalledNumber=921095XXXXX
GwOutpulsedCalledNumber=21095XXXXX
GwOutpulsedCalledOctet3=0x80
GwOutpulsedCallingNumber=1002
GwOutpulsedCallingOctet3=0x0
GwOutpulsedCallingOctet3a=0x0
DSPIdentifier=0/1:1
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 2
Cisctest#show controller BRI0/1/0
BRI unit 4:
layer 1 operating in LT-T mode.
Layer 1 is ACTIVATED. (ISDN L1 State F7)
D Channel Information:
idb at 0x6895DE54, driver data structure at 0x689F7300
Infineon Chip Version 0x1
Infineon Registers:
Int. Status Register [ISTA]=0x00, Aux. Int. [AUXI]=0x00
D-channel: Int. Status Reg: [ISTAD]=0x00, Status. Reg: [STARD]=0x48
Mode Reg: [TR_MODE]=0x01
Transceiver Reg: [TR_CONF0]=0x00
Test mode Reg: [TMD]=0x00
IOM Control Reg: [IOM_CR]=0x08
Status Register [STAR]=0x48, Mode Register [MODED]=0xCA
Serial Data Strobe Control Reg: [SDS1_CR]=0x00, [SDS2_CR]=0x00
RX Buffer Descriptor is at 0x6896F38C, Buffer size 1524
TX Buffer Descriptor is at 0x689D71EC
pak=0x0 data_ptr=0x0 partial_size=0x0
  0 missed datagrams, 0 overruns
  0 bad datagram encapsulations, 0 memory errors
  0 transmitter underruns  0 d channel collisions
B1 Channel Information:
B2 Channel Information:
Thanks again..
