One way audio with FXS port under SCCP control
Ayodeji Okanlawon
I just had an install where I used Vic4-fxs/did to integrate some polycom phones to ccm using sccp.
Howevr I am experiencing a one way voice on them.
I have searched the whole forum for similar problems, but havent found any such thing.
Any ideas will help
Please rate all useful posts
gogasca
Level 10
Level 10
Could you please paste your config
and make sure sccp binding routing is correct?
Are you using vic4 as sccp ?
using mgcp|h323 same issue
between which devices is the one way
gogasca,
attached is my config
