Oneway Audio problem due to BVI interface?
gkonheiser
Hi there,
I am having an issue where external incoming calls can not hear me although I can hear them. I think it could be a routing issue linked to Bridge group and int BVI1 but im not sure : ( . I tried " h323-gateway voip bind srcaddr 192.168.3.100  " on  the int BVI1 but didn't help. Appreciate if someone with more knowledge could take a look at my config to see if its anything obvious, ie do  I need an incoming dial peer?
version 15.1
service password-encryption
hostname CME3.100
boot-start-marker
boot system flash c2800nm-adventerprisek9-mz.151-4.M3.bin
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $xxxxxxxxxx
aaa new-model
aaa authentication login default local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa session-id common
clock timezone CET 2 0
dot11 syslog
ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp binding cleanup interval 10
ip dhcp excluded-address 192.168.3.1 192.168.3.180
ip dhcp pool PHONES
network 192.168.3.0 255.255.255.0
default-router 192.168.3.100
option 150 ip 192.168.3.100
dns-server 8.8.8.8
ip dhcp pool STATIC
host 192.168.3.201 255.255.255.0
client-identifier 01c4.8508.6c95.a3
ip dhcp pool xxxx
host 192.168.3.204 255.255.255.0
client-identifier 0100.25ae.2762.f4
ip dhcp update dns
ip name-server 8.8.8.8
no ipv6 cef
voice service voip
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
  bind control source-interface BVI1
  bind media source-interface BVI1
  registrar server
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice register global
mode cme
source-address 192.168.3.100 port 5060
max-dn 8
max-pool 8
authenticate register
tftp-path flash:
file text
create profile sync 0016587035046141
voice register dn  1
number 8001
name Gordon
label Gordon iPhone5 8001
voice register dn  2
number 8002
name Jay
label Jay iPhone3 8002
voice register pool  1
registration-timer max 720 min 660
id mac 04F7.E4C3.63D1
session-transport tcp
type CiscoMobile-iOS
number 1 dn 1
username gordon password xxxxxxx
v
voice hunt-group 1 parallel
list 8001,1001,1002
pilot 0xxxxxxxx
voice hunt-group 2 parallel
list 1001,1002,8001
pilot 0xxxxxxxx
voice hunt-group 3 parallel
list 8001,1001,1002
pilot +4xxxx
voice-card 0
crypto pki trustpoint TP-self-signed-4147047992
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4147047992
revocation-check none
rsakeypair TP-self-signed-4147047992
crypto pki certificate chain TP-self-signed-4147047992
certificate self-signed 02
  3082022B 30820194 A0030201 02020102 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 34313437 30343739 3932301E 170D3133 30393033 30373431
  34355A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 31343730
  34373939 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100C175 C1C08CB5 1225EB0D 03CC3C69 11FE820D C5BE94F9 2393D9C7 BBAFA729
  B419A199 491D022F DD865CAD 2AD60910 CB316ED7 65456A91 94C1E2D2 5EEDDF35
  3A95F8A6 B4B5A1E9 7675AE9E CF38102B 3805FE5B 7403F9D2 36692F75 EF23B6E3
  0A0514BF 427860A9 CF6B97E8 BBC5D5D5 DFD5ECDF 38B70863 D6F197B5 70806CA5
  3A5F0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 145B297C 689A98F7 5087FE67 24E6C680 56DF2AD7 80301D06
  03551D0E 04160414 5B297C68 9A98F750 87FE6724 E6C68056 DF2AD780 300D0609
  2A864886 F70D0101 05050003 818100A1 4A251FE8 C77AF672 7C3C04A7 69D6D20A
  779B577D 349C25DB 668AD407 D222D143 27AF85A6 33A9BC4B EBAD93A4 80278EB0
  A60284E6 9800C7C8 63E6BAEC E32BCC56 CEE30C84 EDBF04C2 25E33382 D91C3266
  3B5880AD 3D2E4F47 56A01242 37C0806F 25F574CA 02F4721E 4FBFE135 D94B8C3B
  F0EDAF11 C9792CE7 09814BE8 E62099
        quit
license udi pid CISCO2821 sn FCZ114971YA
archive
log config
  hidekeys
username gkonheiser privilege 15 secret 5 $1xxxxxxxxxxxxxxxxxxxxxxxx
username administrator privilege 15 secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
username Jay secret 5 xxxxxxxxxxxxxxxxxxxxxxxx1
redundancy
no ip ftp passive
ip ssh port 2001 rotary 1 10
ip ssh version 2
class-map match-all priority
match protocol skype
policy-map outbound
class priority
  priority 2000
crypto logging session
crypto logging ezvpn
crypto ctcp port 10000
crypto isakmp policy 1
encr aes
authentication pre-share
group 2
crypto isakmp client configuration address-pool local SDM_POOL_1
crypto ipsec transform-set ESP-3DES-SHA esp-aes esp-sha-hmac
crypto ipsec profile Test
set transform-set ESP-3DES-SHA
crypto ipsec client ezvpn CISCOCP_EZVPN_CLIENT_1
connect manual
group astrill key way2stars
mode client
peer UK1.ASTRILL.NET
virtual-interface 1
username gkonheiser@hijinxx.com password 9729209
xauth userid mode local
bridge irb
interface GigabitEthernet0/0
description WAN
ip address xxxxxxxxxxxxxx
ip flow ingress
ip nat outside
ip virtual-reassembly in
duplex full
speed 100
service-policy output outbound
interface GigabitEthernet0/1
description LAN
no ip address
ip nat inside
duplex full
speed 100
bridge-group 1
interface FastEthernet0/0/0
no ip address
interface FastEthernet0/0/1
no ip address
interface FastEthernet0/0/2
no ip address
interface FastEthernet0/0/3
no ip address
interface Virtual-Template1 type tunnel
no ip address
tunnel mode ipsec ipv4
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip address 192.168.3.100 255.255.255.0
ip nat inside
crypto ipsec client ezvpn CISCOCP_EZVPN_CLIENT_1 inside
ip local pool SDM_POOL_1 192.168.3.230 192.168.3.235
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source static udp 192.168.3.244 25565 interface GigabitEthernet0/0 25565
ip nat inside source static tcp 192.168.3.244 25565 interface GigabitEthernet0/0 25565
ip nat inside source static tcp 192.168.3.43 3389 interface GigabitEthernet0/0 26999
ip nat inside source static tcp 192.168.3.6 14565 interface GigabitEthernet0/0 14565
ip nat inside source static tcp 192.168.3.111 11767 interface GigabitEthernet0/0 11767
ip nat inside source static tcp 192.168.3.3 3389 interface GigabitEthernet0/0 27000
ip nat inside source static tcp 192.168.3.4 26252 interface GigabitEthernet0/0 26252
ip nat inside source static tcp 192.168.3.6 3389 interface GigabitEthernet0/0 23389
ip nat inside source static tcp 192.168.3.204 53 interface GigabitEthernet0/0 53
ip nat inside source static udp 192.168.3.204 53 interface GigabitEthernet0/0 53
ip nat inside source static tcp 192.168.3.204 80 interface GigabitEthernet0/0 80
ip nat inside source static tcp 192.168.3.204 3074 interface GigabitEthernet0/0 3074
ip nat inside source static udp 192.168.3.204 3074 interface GigabitEthernet0/0 3074
ip nat inside source static tcp 192.168.3.202 53 interface GigabitEthernet0/0 54
ip nat inside source static udp 192.168.3.202 53 interface GigabitEthernet0/0 54
ip nat inside source static tcp 192.168.3.202 80 interface GigabitEthernet0/0 81
ip nat inside source static tcp 192.168.3.202 3074 interface GigabitEthernet0/0 3075
ip nat inside source static udp 192.168.3.202 3074 interface GigabitEthernet0/0 3075
ip route 0.0.0.0 0.0.0.0 93.83.171.9 2
access-list 1 remark Internet access list
access-list 1 permit 192.168.3.0 0.0.0.255
access-list 111 permit udp any any eq 3074
access-list 111 permit tcp any any eq 3074
access-list 111 permit udp any any eq 88
tftp-server flash:phone/7906-7911/SCCP11.8-3-3S.loads alias SCCP11.8-3-3S.loads
tftp-server flash:phone/7906-7911/apps11.8-3-2-27.sbn alias apps11.8-3-2-27.sbn
tftp-server flash:phone/7906-7911/cnu11.8-3-2-27.sbn alias cnu11.8-3-2-27.sbn
tftp-server flash:phone/7906-7911/cvm11sccp.8-3-2-27.sbn alias cvm11sccp.8-3-2-27.sbn
tftp-server flash:phone/7906-7911/dsp11.8-3-2-27.sbn alias dsp11.8-3-2-27.sbn
tftp-server flash:phone/7906-7911/jar11sccp.8-3-2-27.sbn alias jar11sccp.8-3-2-27.sbn
tftp-server flash:phone/7906-7911/term06.default.loads alias term06.default.loads
tftp-server flash:phone/7906-7911/term11.default.loads alias term11.default.loads
tftp-server flash:phone/7937/apps37sccp.1-1-1-1.bin alias apps37sccp.1-1-1-1.bin
tftp-server flash:flash/apps37sccp.1-2-1-0.bin alias apps37sccp.1-2-1-0.bin
tftp-server flash:phone/7921/CP7921G-1.4.5.3.loads alias CP7921G-1.4.5.3.loads
tftp-server flash:phone/7921/APPS-1.4.5.3.SBN alias APPS-1.4.5.3.SBN
tftp-server flash:phone/7921/GUI-1.4.5.3.SBN alias GUI-1.4.5.3.SBN
tftp-server flash:phone/7921/SYS-1.4.5.3.SBN alias SYS-1.4.5.3.SBN
tftp-server flash:phone/7921/TNUX-1.4.5.3.SBN alias TNUX-1.4.5.3.SBN
tftp-server flash:phone/7921/TNUXR-1.4.5.3.SBN alias TNUXR-1.4.5.3.SBN
tftp-server flash:phone/7921/WLAN-1.4.5.3.SBN alias WLAN-1.4.5.3.SBN
control-plane
bridge 1 protocol ieee
bridge 1 route ip
mgcp fax t38 ecm
mgcp profile default
dial-peer voice 44 voip
description UK CALLS WITH 0044
destination-pattern 0044..........
session protocol sipv2
session target dns:sipgate.co.uk
voice-class codec 1
dtmf-relay rtp-nte
ip qos dscp cs5 media
clid network-number 17xxxxxx
no vad
dial-peer voice 49 voip
description GERMANY CALLS WITH 0049
destination-pattern 0049.........
voice-class codec 1
dtmf-relay sip-notify rtp-nte
clid network-number 17xxxxxxx
no vad
dial-peer voice 43 voip
description AT CALLS WITH 0043
destination-pattern 0043..........
voice-class codec 1
dtmf-relay rtp-nte
clid network-number 179xxxxx
no vad
dial-peer voice 1 voip
session target ipv4:192.168.3.100
incoming called-number 0044xxxxxxxxx
voice-class codec 1
no vad
sip-ua
authentication username 1799999 password 7 xxxxxxxxxxxxxxxxxxxxxx realm sipgate.de
authentication username 1799999 password 7 xxxxxxxxxxxxxxxxxxx realm sipgate.co.uk
no remote-party-id
set pstn-cause 6 sip-status 503
set pstn-cause 18 sip-status 408
set pstn-cause 27 sip-status 502
set pstn-cause 31 sip-status 480
set pstn-cause 44 sip-status 503
set pstn-cause 58 sip-status 503
set pstn-cause 88 sip-status 503
set pstn-cause 95 sip-status 503
set pstn-cause 102 sip-status 504
set pstn-cause 111 sip-status 500
retry invite 4
retry response 3
retry bye 2
retry cancel 2
retry register 10
timers trying 1000
timers connect 100
timers register 250
registrar 1 dns:sipgate.co.uk expires 3600
registrar 2 dns:sipgate.de expires 3600
sip-server dns:sipgate.co.uk:5050
telephony-service
em logout 0:0 0:0 0:0
max-ephones 58
max-dn 192
ip source-address 192.168.3.100 port 2000
service phone displayIdleTimeout 00:30
service phone displayOnDuration 1:00
timeouts interdigit 8
timeouts ringing 20
system message Hijinxx
cnf-file location flash:
cnf-file perphone
network-locale GB
network-locale 1 GB
network-locale 2 GB
network-locale 3 GB
network-locale 4 GB
load 7906 SCCP11.8-3-3S.loads
load 7911 SCCP11.8-3-3S.loads
load 7921 flash/CP7921G-1.4.5.3.LOADS
load 7937 apps37sccp.1-1-1-1.bin
time-zone 23
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
web admin system name gkonheiser secret 5 $1
transfer-system full-consult
directory entry 1
directory entry 2
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1  dual-line
number 1001
ephone-dn  2  dual-line
number 1002
ephone-dn  10
number +44845xxxxxxxx Secondary 1796xxx
ephone-dn  11  dual-line
number +49524xxxxxxx secondary 1799xxx
ephone  1
no multicast-moh
device-security-mode none
mac-address 001F.9E8B.A45F
max-calls-per-button 4
username "gordon" password
type 7921
button  1:10 2:11 3:1 4:2
ephone  2
mac-address 0022.90FD.5EEE
type 7921
line con 0
password 7
line aux 0
line vty 0
session-timeout 360
exec-timeout 360 0
password 7
logging synchronous
transport preferred telnet
transport input telnet ssh
line vty 1 4
session-timeout 360
exec-timeout 360 0
password 7
logging synchronous
transport preferred ssh
line vty 5 988
exec-timeout 30 0
logging synchronous
scheduler allocate 20000 1000
ntp update-calendar
ntp server 129.6.15.28
end
Hope I havent left anything sensitive in.
paolo bevilacqua
Without knowing full network details, it's impossible to say. anything.
gkonheiser
Problem solved, changed:
sip
to
sip
  bind control source-interface GigabitEthernet0/1
  bind media source-interface GigabitEthernet0/1
all good now.
