Only one E1 Port works -- 2821 / AdvIPSrv 12.4.24T3 / VWIC2-2MFT-E1
jecheand
Hi, i have this simple scenario IP PHONE -> LAN -> GW -> PSTN with a CUCM 7.1 BE, 2821 with a vwic2-2mft-e1 and two isdn lines connected to both e1 ports (voice).
I have configured the gateway as MGCP both e1 ports appear registered but the problem is that when i want to call through the second e1 port 0/0/1:15 the call didn't complete. It appears the error:
i = 0x82D2 - Identified channel does not exist
The funny thing is that when i move the second isdn e1 cable from the 2821 and move it to another router 2811 with a vwic-1mft-e1 (one voice port) configured as same as the other port it works fine.
So finally, i only can have one e1 port configured on the 2821 0/0/0:15 and one on the 2811 0/2/0:15. The second port on the 2821 0/0/1:15 didn´t work for outbound call but for inbound is fine.
Can anyone help me with this, thanks for your time.
Jose
Harmit Singh
Hi Jose,
Not sure if this issue has already been addressed. If not, please send me the following details:
++     show tech from the 2821
++     show isdn status
++     show isdn service
++     debug isdn q931
++     debug isdn error
++     debug ccm-manager backhaul packets
++     debug ccm-manager backhaul events
++     debug mgcp packets
++     detailed CUCM SDI traces with "Enable All GateWay Trace" and "Enable MGCP Trace" boxes checked.
Place a single outbound call from the 2nd E1 and collect the above mentioned outputs for that call. Also, mention the calling and called party numbers for that call.
Harmit.
