Operation third-party sip Grandstream on CUCM
pablo.fescobedo
I have a CUCM in version 9.1 with third-party sip phones Grandstream, this phones work fine and the calls are conducted properly.
But, i can't configure a button on the phone to pickup calls or do direct tranfer.
Someone know if is possible?
BR
Pablo
Rajan
Hi Pablo,
I guess its not possible as there is a limitation with third party sip phones that softkey templates cant be used.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/7_1_2/ccmcfg/bccm-712-cm/b09sip3p.html#wp1023829
Rajan
Hi rayan,
Thanks for the feedback.
Although the softkeys template can't be used, you know you if possible use the phisical buttons?
BR
Pablo
Hi Pablo,
All configuration in third party phone will be locally only and feature will work as per phone's local implementation.
- Vivek
Thanks for your fast response.
Now, i have clear integration between CUCM and third-party SIP phones.
BR,
Pablo
