Register AVAYA Phone 9620L with CUCM 8.5.1
Syed
Level 3
Level 3
Dear All,
I have bought a new Avaya IP phone (model 9620L) and I want to register this to CUCM 8.5.1 as a basic third party SIP phone to test.
Request you to help me with sample configuration.
Thank you in advance.
2 Accepted Solutions
Ayodeji Okanlawon
Please refer to the following documents/Links on how to set this up
https://supportforums.cisco.com/document/50491/how-register-third-party-sip-phones-communications-manager
http://www.netcraftsmen.com/sip-endpoints-in-cisco-cucm-x-lite-as-an-example/
https://www.youtube.com/watch?v=PX44o4gZrzo
Please rate all useful posts
Adarsh Chauhan
Level 3
Level 3
Hi Syed,
I believe your first step should be to figure out if this phone supports Digest Auth or not.
if it doesn't then you need to create a user same as the line assigned to this phone.
Assign the user this phone and make primary extension the line of this phone.
if it does support Digest Auth then you can simply follow the procedure mentioned in this doc.
Please rate if helpful.
Adarsh Chauhan
Please rate and mark correct if helpful
Adarsh Chauhan
Ayodeji Okanlawon
Hello Ayodeji/Adarsh,
Thank you for your quick help & support.
Adarsh Chauhan
Level 3
Level 3
Hi Syed,
Adarsh Chauhan
Adarsh Chauhan
