Ordering CUCM, CUC and CUP (9.x)
Edson Vuma
Hope you are all fine.
I want to know how I can proceed to make a Billing Of Material for the products on the Subject of the forum?
The solution must be virtualized.
So I dont know how I can make this BOM.
What are the part numbers I can use in order to make this sucessfully.
Its important to tell that must be in cluster.
Any help?
Edson Vuma
-- Regards Edson Vuma
8 Replies 8
ronpatel
Level 8
Level 8
BOM creating takes lots of efforts and I suggest you to contact PH team for this. If you are Cisco partner, You can contact Cisco PH team at cisco.com/go/ph. Open case with them and they will help you on this.
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi Edson,
In addition to what Mr. Ronak has said, u can also refer Ordering Guides for details.
http://www.cisco.com/web/partners/sell/technology/ipc/uc_tech_readiness.html
regds,
aman
Hi, Ronak and Aman.
Thanks for your help.
Checking both suggestions now.
Anything else I will let you know.
Edson Vuma
One more question...
For not-virtualized solution.
How I can do it?
What are the part numbers of the appliances?
Best regards
/EV
Hi, Aman.
Thanks for your email.
1. I only could make the BOM with the CUCM on CCW.
2. For IM & Presence, CCW is giving a "cant be found" message. I didnt test all of them.
3. For Unity, I cant see the servers.
So, can you help me with the recommended ones?
Best regards
/EV
Edson Vuma
Hi Edson,
I would have definitely helped u in case I had worked on Cisco Commerce Workspace tool.
U need to involve your Ordering team.
regds,
aman
Hi, Aman
You can give me the part numbers and I can make a configuration on CCW.
What about that?
Edson Vuma
