Other languages than English on 7800 series phones using CUCM 8.5.1
jayage
Hi guys,
I need some help. We want to install Italian and German language for the 7800 series IP phones. Several months ago we've installed the necessary device pack to support those phones on our CUCM cluster. Now we want to provide furhter languages for the phones. Can someone please post the urls for the right locale files we need? I don't know which version we have to choose.
Thank you in advance!
johaas
Show version under OS Administration lists the following elements as active:
cm-locale-bg_BG-8.5.1.1000-1.cop Active
cm-locale-combined_network-8.5.1.1000-1.cop Active
cm-locale-cs_CZ-8.5.1.1000-1.cop Active
cm-locale-da_DK-8.5.1.1000-1.cop Active
cm-locale-de_DE-8.5.1.1000-1.cop Active
cm-locale-es_ES-8.5.1.1000-1.cop Active
cm-locale-fr_FR-8.5.1.1000-1.cop Active
cm-locale-it_IT-8.5.1.1000-1.cop Active
cm-locale-pt_PT-8.5.1.1000-1.cop Active
cm-locale-zh_CN-8.5.1.1000-1.cop Active
cmterm-6901_6911-sccp.9-3-1-SR1-3.cop Active
cmterm-6945-sccp.9-3-3-2.cop Active
cmterm-69xx-sccp.9-3-3-2.cop Active
cmterm-78xx.10-1-1-9.cop Active
cmterm-devicepack8.5.1.17114-1.cop Active
cmterm-devicepack8.5.1.17126-1.cop Active
cmterm-devicepack8.5.1.17133-1.cop Active
localeinstaller Active
Current version we're running is: 8.5.1.10000-26
Please let me know if you need further information :)
Jaime Valencia
The README/RNs for the language packs contain the info of what devices they support, have you reviewed that?
java
if this helps, please rate
I read a lot of those readme files so I got totally confused - thus I am posting :D
Can someone please help?
I'd appreciate it!
The locales can be downloaded from the following link
https://software.cisco.com/download/release.html?mdfid=284892536&flowid=46503&softwareid=282074291&os=Linux&release=11.0%281%29&relind=AVAILABLE&rellifecycle=&reltype=latest
If you check the Read me file that is presented by moving the cursor over the locale file name ( see below )  , it says that  this can be installed on any version of Cisco Unified Communications Manager which supports Cisco IP phone firmware 11.0.1.
http://www.cisco.com/web/software/282074291/130123/po-locale-11.0.1.1000-1_ReadMe.pdf
So basically it should be okay for your cucm version.
Manish
